shockwave 26 prop questions
  • 26Incheslong
    • Jun 2011
    • 7
    Ok so I got a shockwave 26 broke the stock plastic prop upgraded to a bigger brass one it didn't seen to much bigger and 5secs in the water and the esc caught fire. Stock everything beside prop with a 60c 6000 lipo, was told it was a known problem they replaced electronics
    Today I got my replacement parts and went out again it seems to kill batteries pretty fast and it puffed my 60c 6000
    Ok so my question is...
    Is the prop to big?
    What prop is the best upgrade?
    Be easy on me lol
  • roadrashracing
    • 1630
    probat makes a stainless one for it, thats stock size, they where supose to be including them with the newer boats, but fill this out and they will send you one.
    • Boaterguy
      • 1779
      if you didn't balance or sharpen it, it will not be good on the electronics. if you did balance and sharpen, a 60C shouldn't puff, that's a pretty big battery.
      • Pete32200
        • 281
        A prop thats a few mm bigger may not "seem" that much bigger but adds alot more load on the electronics, the stock esc barely handles a stock size prop so anything bigger will usually toast it
        I ran an X435 prop on mine and loved it
        VS1 FE - UL-1 - Motley Crew - Miss Geico - Kintec Prince - Rio 51z - 1/16 Summit - 1/10 Summit - Ken Block Rally - Kyle Busch Truck - Losi Mini SCT - BL E-MAXX - Assoc FT SC10 - Wild Willy - Clodbuster - Sand Scorcher......
        • 26Incheslong
          • Jun 2011
          • 7
          The x435 prop seems to be what everyone is running, ill probably upgrade the esc to a 120amp hobbyking esc and run my 3s in it later
          After greasing the shaft realigning everything its a lot smoother, but its still causing the batteries to heat up bit. all the electronics seem fine I'm running it on my Orion 30c 3800 and its fast I'm gonna order the x435 and make this a recovery boat and build something new
          Like this but bigger
          • Pete32200
            • 281
            The Shockwave is a good boat to wet your appetite for FE but it doesn't take long until you start wanting more speed!!!
