why are FE boats not using 4 or 5 blade prop?
  • fuse01
    • Feb 2011
    • 46
    i was just watch the miss geico ( real ones) and they have sick 6 blades props.
    so the question is why are we not using 4 or 5 blades? what are the limitations ?
  • Ub Hauled
    • 3031
    I have a 5 blade prop and tried it... it turns out it would not hook... I believe that there is too much aeration.
      • 7990
      Small diameter multi-bladed props don't work well on most models. Two or three bladed props are the fastest. Some things just do not scale down well.
      • epsonjackson
        • May 2011
        • 10
        it would have been great if it could scale down well, 5-6 props would have been better
        1 year Money back Guarantee Epson ERC-38BR | Epson T069520
        • egneg
          • 4664
          The only one I know that has had any luck with them is graill. He used a pair of prop shop 8015/5's cut down to 65mm on the Platinum Princess. This is a 96" cat and the amp draw went up and run time went down. He said he would try them again after he got the turbines put in.
          Chuck
          IMPBA 20481S D-12
          • Boaterguy
            • 1760
            It would be neat to try, maybe i'll get one for my rigger, just for looks and fun, would a 35mm/5 be about = to a x447?
            Edit: I just went on propshop and I couldn't find any 5 blade, where should I look?
            • Punisher 67
              Ignore list member #67
              • 1481
              I once tried a 5 blade prop on my 57" Apache , I was an absolute turd.....in-fact it ultimately bent the 3/16 shaft from cavitation
              • jevmax
                Legend
                • 368
                Two primary reasons. Load and drag.
                • jcald2000
                  • 768
                  And we turn our props a lot more rpm so the wake from preceding blade is disturbing the flow around the trailing blade. You won't see any 30,000 rpm shaft speeds on the big boats. At least not when I was racing them 20 years ago. LOL
                  • Boaterguy
                    • 1760
                    Oh, so pretty much lots of aeration?
                    • bigwaveohs
                      • 535
                      Imagine the fun to S&B a 5-blade prop!
                      I let the dogs out...
                      • Gary
                        • Jan 2009
                        • 1104
                        All you have to do is buy an Eagle Tree set up to test all the mods you make on your boats. Its the best part of boating in my opinion. This way any prop change will show the MPH and RPM so you can work from there. You just cant guess from "eye ball" readings.
                        H&M 1/8 Miss Bud 73 mph
                        Chris Craft 16 mph
                        • Punisher 67
                          • 1481
                          Yes I lived through that , It was a challange .
                          • Boaterguy
                            • 1760
                            How is it done?
                            • egneg
                              • 4664
                              To modify a 5 blade and then S/B it is a real challenge. I did the work for graill's props.
                              IMPBA 20481S D-12
