45mm Props NEED HELP
  • monojeff
    • Nov 2010
    • 2728
    They are graupner 45mm counter rotating props which are going to be pushing a twin 550 brushed 32" mono which I will be using as a retrieval boat.
    The motors are proboat apache 550s.
    I am not sure what the pitch is on the props but it says hydro on them which I did not realize when I got them.
    Can I possibly cut them down or should I get new props??
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
  • monojeff
    • Nov 2010
    • 2728
    I believe I found the prop somewhere and it says rise 54mm not sure if that helps.
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • sailr
      • 7128
      They are most likely 63 or 64mm pitch. If I were you I'd go ahead and try them. Run for about 45 seconds and then bring boat in and check temps. If too hot, get smaller props.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • monojeff
        • Nov 2010
        • 2728
        Yeah I think your right on that 62-64mm pitch from what I could gather.
        You think I should test them under load of pushing something or test without first then test while pushing or pulling a boat.
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • monojeff
          • Nov 2010
          • 2728
          Any thoughts on how many amps you think I will be pulling?
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
          • U1Racing
            • 62
            Jeff, what are you planning to use as a rig on it to hook the boats to it??
            too much power not in the FE racing dictionary
            • monojeff
              • Nov 2010
              • 2728
              I plan to make some sort of arms on the front of the boat to push them back to shore.
              OSE GIFTING ELF
              HAPPY HOLIDAYS!!
              • sailr
                • 7128
                Not sure how you would test other than on a boat! Any other test would be inconclusive.
                Mini Cat Racing USA
                • Boaterguy
                  • 1779
                  If it is a rescue, speed shouldn't be a problem, you could lower the cell count or something in order to bring rpm's down, propping then wouldn't be a problem.
                  • egneg
                    • 4759
                    You could always run them through a gear box which will decrease rpm and increase torque.
                    IMPBA 20481S D-12
