prop help fore the rigger I built
  • elijah
    • Oct 2010
    • 118
    I took the predater outrigger plans and enlarged them to build a 32'' rigger it came out grate totle wate redy to run no batt. 4.2 lb. running on the ul1 motor and esc using the turnigy 5.0 40-50 c brick that is 20.6 oz. I am running the octura m447 and getting speeds in the high 50s to the low 60s blistering the other racers in my club hawever after the 5 lap race my caps and motor are so hot they will blister you if you tutch them hawever I am not getting a smocking genie I think I need to use a smoller prop but I am a newbe and can't figure out what would be a good prop to use to cool down without loosing any speed or as little speed as posable. can any one help. thanks
  • eric_laermans
    • Nov 2010
    • 96
    Dear Elijah,
    Definitely start with smaller prop. For same configuration I would start with 38mm prop and work up little by little.
