props for my UL-1
  • wild bill
    • Feb 2010
    • 40
    props for my UL-1
    any suggestions on props for my UL-1.we can't change motor or esc in boat (club rules).i am currently running a octura 440 3 blade or 442 2 blade.
  • Shooter
    Team Mojo
    • Jun 2009
    • 2751
    Haven't run the UL-1 in a year or so, but the 440/3 is a great all around prop. If you want to push it, try the grim 40x57/3. Make sure it is REAL sharp. It will probably cavitate a bit on start, but when she catches, hold onto your hat!! Watch temps closely though and make sure you've added caps if you have an older esc. Good luck!
    • m4a1usr
      Fast Electric Addict
      • 2036
      Look in the "Aquacraft" section on OSE. There is a UL1 area that has some decent info on prop choices. You can go up to a M445 using the stock components providing you move the strut down some. Do a search and it all there.
      John
      Change is the one Constant
      • LiPo Power
        DJI Drone Advanced Pilot
        • 3678
        Hey try on Grim L45x68 and stock ESC and motor!!!
        That thing will fly!! Slow down a little when turning!
        Robert
        Canada
        • wild bill
          • Feb 2010
          • 40
          thanks guys.i will give those props a try.i heard a h-5 prop might be a possiblity also. any opinions?
          • wild bill
            • Feb 2010
            • 40
            ok guys:i was looking thru my prop box & ran across a grim L40x67.do you think this will work? boat won't get on step with stock strut setting.any sugg's
            • detox
              • 2357
              M445 is a verygood prop. Everybody needs one of these in their prop box.
