3 blade prop balanc
  • Gen
    • Dec 2010
    • 107
    3 blade prop balanc
    now ,i have a grim racer 3 blade prop
    ,i have sharpened it but want to balance ,i have a magntic prop balancer and when installed i do i have 1 heavy blade that drops down ,now will i just do oppisite 2 blades a bit till prop can sit at any position without turning ..
    Regards Gen
  • D&D
    • Aug 2009
    • 185
    Just the opposite, the bottom blade is the heavy blade and that is the one that needs to be worked on.
    • carlcisneros
      • Jan 2010
      • 1218
      take your time and you will be pleased.
      • egneg
        • 4664
        3 bladed props are a bit more of a challenge and take more time - also don't forget that the hub can also be worked to help balance the prop.
        IMPBA 20481S D-12
        • Gen
          • Dec 2010
          • 107
          the hub ??
          Wow never thought of that but obviosly thats a fine tune point and you should be concentrating on blades ??
          Also how do i know im done ,when prop can sit in any position on balancer without movin much (within reason ) ??
          • egneg
            • 4664
            Yes to both questions.
            IMPBA 20481S D-12
            • dasboata
              • Dec 2010
              • 3152
              3 blades are easer to Balance then 2 blades,, the more blades the easer it is to balance,,I did over 1200 props last year so ask me how I know Thanks chris
              • egneg
                • 4664
                For someone just starting out 3 blades are a bit more challenging. It's like going from 2 dimensional to 3 dimensional thinking when you have to work 2 heavier blades against the 1 lighter blade. Maybe you could offer some tips on how you do your props.
                IMPBA 20481S D-12
