Is an Octura 1740/3 a good prop for....
  • Karfrik
    • Jun 2009
    • 1177
    a 25" Maus/Bandit shovel running on 4S,Ammo 2300,MissGeico/proboat esc?......does it has the right lift for it or is it overkill?....thanks,...Al
  • dasboata
    • Dec 2010
    • 3152
    1700 series are good for outboard riggers try it and see good luck !!
    • Chris Harris
      • Oct 2007
      • 182
      To expound on what dasboata said the 17 series are about the highest lift props Octura makes. The reason they work so well on O/B hydros. You may need to do some mods to the prop to make it work on a sport hydro and/or use a very high strut setting to compensate. We use to run 17 series a lot in oval riggers and they performed really well. Because of the blade progression they are very effecient but they do require a little different setup than lower lift props.
      Chris
      I.M.P.B.A. Record Holder P-Hydro 111.001mph Q-Hydro 120.192mph S-Hydro 139.233mph
      • Karfrik
        • Jun 2009
        • 1177
        thanks guys,...anyone more suggestions on this prop?.....bump!!!
        • egneg
          • 4664
          I run a Prather 215 in my Campbell Vintage shovel on the same motor.
          IMPBA 20481S D-12
