Attaching flex cable too
  • Riversidedan50
    • Feb 2025
    • 46
    needing to know how you guys attach a prop shaft to a flex cable solder or loctite if so which kind?
  • oscarel
    • Dec 2009
    • 2373
    Either will work, here's an article that might help.
    https://www.offshoreelectrics.com/pr...=art-glue-flex
      • 4340
      I glue my cables into drilled stub shafts with Loctite 648. A proper fit and good surface preparation are key.
      • lucassinner
        • Jul 2025
        • 1
        I’ve always had the best results silver soldering the flex cable to the prop shaft; it holds up great under load and never slips. Some guys use Loctite 638 or 680, but in my experience, soldering gives more peace of mind, especially with high-power setups.
        • Riversidedan50
          • Feb 2025
          • 46
          ok thanx.........am still using 3.17 cable so will give 638 a shot and see if it holds up
