Octura Aluminum Props
  • Christaphason
    • Jun 2009
    • 107
    Has anyone tried these on a brushless setup? It clearly states it is not recommended for brushless set ups.
    But, im wondering why isn't it recommended?
  • NitroVal
    • Jun 2009
    • 423
    Aluminum doesnt have the same strength as the beryllium/titanium yada yada stuff that their normal props do..
    The RTR Nightmare- Electric King of Shaves
    Now with 540s- 62mph
    New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
    • mikesf
      • 96
      Yes but balancing them is not a health hazard as beryllium...
      • Team FFRB
        • 328
        Ali Props
        http://en.wikipedia.org/wiki/Beryllium#Toxicity
        I have used them as test props only.
        Before to long they will blow a blade off from the stress.
        HOT RODS ON WATER
          The aluminum has more negatives than positives for BL power.
          - The blades cannot be sharpened enough and the result is non-optimal performance - prop walk, low efficiency.
          - The castings are porous and don't polish or smooth well
          - The weak nature of the metal can result in easily-thrown blades - dangerous!
          - Aluminum is not without its own health concerns - it is a known neurotoxin. I'd rather have berrylium poisoning (treatable) than alzheimers!
          http://www.angelfire.com/az/sthursto..._toxicity.html
          Bottom line - follow the manufacturer's recommendations.
          • Christaphason
            • Jun 2009
            • 107
            Thanks, i figured it was a strength issue, just wondering if there was anything more to the reasoning.
            Thanks.
