cats and struts
  • lincpimp
    • Jul 2007
    • 252
    Take a look at these links, you can see the stuffing tube just sicks out the back of the boat. I have the gecko and it works gear. Run a k series carbon 29mm prop, 2s lipo, gh 4700kv motor and a mamba 25 esc. No water cooling, just a finned motor and it runs like a champ, at least 25mph and it will launch out of the water from rest.
    The purple gecko shows the al stuffing tube the best.
    "These rocky mountains aren't very rocky!" "Yeah, that John Denver is full of S**t!"
    • screwball
      • Jul 2009
      • 464
      since this will be my first lipo im just gonna go with the easy stuff
      charger- http://www.hobbycity.com/hobbycity/s...idProduct=8247
      battery- http://www.hobbycity.com/hobbycity/s...idProduct=7309
      motor- http://www.hobbycity.com/hobbycity/s...idProduct=4194 ( its a couple bucks cheaper )
      and some peal and stick foam http://www.hobbycity.com/hobbycity/s...idProduct=8999
      so assuming my strut works ill have a complete running bl micro scat cat for 85 bucks!!!
      -James
      • screwball
        • Jul 2009
        • 464
        so maybe i wont need the strut hahaha cool
        • domwilson
          • 4405
          I think that is a little bit of a different beast. Those have a solid shaft with a solid tube. No flex there. The solid tube and the bearings support the shaft. Ya really can't do that with a flex shaft and no rear support.
          Government Moto:
          • screwball
            • Jul 2009
            • 464
            oh ok well then it looks like strut it is lol
            -James
            • Simon.O.
              • Oct 2007
              • 1521
              If you notice the boats mentioned above do not have a strut as they are a vee hull. It is easy to run a stuff tube out the rear of a vee without a strut. I have 3 vees and have tried this on 2 of them .
              Your original post mentions a scat cat.
              Running a cat with out some sort of strut will be interesting.
              • lincpimp
                • Jul 2007
                • 252
                The gecko does use a wire drive, and the actual prop shaft is as long as the tube that sticks out. No bearings, just a bushing. I do agree that it would not work on a larger boat, or a cat. The straight line nature of the al tube is where it gets its strength, plus the boat weighs next to nothing...
                • domwilson
                  • 4405
                  Let it whip!
                  Government Moto:
                  • Jesse J
                    scale FE enthusiast
                    • 7241
                    I'm with Simon AND I made the stuffing tube in the said cat. In this case, the stub does NOT enter the stuffing tube like on the vees, rather it dangles. If you run without a strut your prop will be whipping around like a wet noodle; you WILL damage the flex and could damage your prop and/or hull. Highly NOT recommended.
                    Make yourself a strut with 1/16" or 1/8" brass plate and a 5/32" K&S tube, will cost less than $5 and require few tools and little manufacturing. You would need a hobby saw and soldering iron. Actually you can use aluminum (if you have access to a band saw) and glue ( JB weld) the 3/16" K&S and slide the 5/32" bushing tube in, see my thread below (here I just glued the 5/32" brass tube directly, no internal bushing):
                    http://forums.offshoreelectrics.com/...ead.php?t=6561
                    Do yourself a favor and wait for the strut, you will be glad.
                    Oh and for motors, I like your ebay option of post 5. I have seen these things fly on the mystery combo that I show in my micro cat post linked above. The only time I ran this thing was when I had a 540S on 2S and it was out of the water more than in... Way over powered. Get used to it with the brushed system and then ease into the brushless, remember its a micro not a monster.
                    "Look good doin' it"
                    See the fleet
                    • screwball
                      • Jul 2009
                      • 464
                      the jb weld on my strut is dyring as i type this ill have pics of it tommorow
                      -James
                      • screwball
                        • Jul 2009
                        • 464
                        heres a few pics of the strut
                        i think it came out pretty good considering its my first try at making one
                        • Tom M
                          • Apr 2008
                          • 150
                          Looks great James. Keep us updated on how it works on your boat when you receive it.
                          • Jesse J
                            scale FE enthusiast
                            • 7241
                            Great, James. That is 99% of the game, take a stab at it and it will probably work! You will have your boat soon and you can work out the details.
                            See the fleet
                            • screwball
                              • Jul 2009
                              • 464
                              yea im thinking that if i get the boat thrusrday or friday im going to work on it until its ready to hit the water lol
                              ive already got a few places to run it picked out
                              thanks again jesse,
                              James
