Who's Running a Micro? => Less than 16"
  • Meniscus
    Refuse the box exists!
    • 3222
    #31
    I figured I'd bring this one back up.
    We may need a new definition for micro:
    WOW THAT IS SMALL!!!
    • wakeboardfusion
      • 462
      #32
      wow, now that is truly micro
      • damfurst
        • 261
        #33
        I didn't know "Oh, Oh" was German for my prop fell off lol. I can't believe how small that was. I guess mine won't qualify now.
        • screwball
          • Jul 2009
          • 464
          #34
          not to be immature but THATS WHAT SHE SAID!!!!!
          ive got a renegade rigger, a minicat velocity mono and a bby micro scat cat. the monoand the cat run around 35mph and i havent tested the renegade yet
          the velocity mono is stock also a little bit over 16 in but i figured id throw it in.....
          Length Overall: 450mm (17.7 in)
          Beam: 124mm (4.88 in)
          Weight: 18.3oz (not including receiver and battery)
          Hull - Epoxy resin/Fiberglass Hull
          Power - Water cooled B24 x 45L Brushless Motor
          ESC - Water cooled 30A with BEC
          Prop - 2 Blade Carbon filled
          Boat Stand - Plywood
          Strut - Aluminum and Stainless Steel
          Rudder - CNC machined, anodized aluminum and stainless steel
          Flexshaft Drive System - Stainless Steel and Brass
          Turn fins (2) - CNC machined, anodized Aluminum
          Ultra plug installed on ESC with mating plug included
          Hatch seal tape included
          Servo -18g
          Speed: 30-40mph
          and im running a 1550mah 3s 20c rhino lipo
          the renegade is the reccommended setup with a 1330mah turnigy lipo
          the micro scat cat
          esc- custom watercooled 40A mystery
          Motor- feigao 380 11s
          prop- stock minicat racing velocity mono prop
          hardware is my own custom made stuff out of brass
          running 2 1250mah rhino 20c 2s lipo`s in parallel
          • Rumdog
            • 6453
            #35
            pics of the cat?
            • old guy
              • 687
              #36
              I have a mini cat hydro. It has a castle creations 4600kv motor and is set up for
              4s. the motor is almost as big as the boat lol. carbon props just blow up after a couple runs so when the water is soft again I will try a metal one. how fast, to fast but it turns. when you pin it it will jump out of the water and land about 15 feet away. I will try to find the youtube fid
              Old guy
              • Meniscus
                • 3222
                #37
                Could you share a link and specs for the Turnigy lipo? Thanks! I'm always interested to see what lipos others have been using in their small models.
                • Rumdog
                  • 6453
                  #38
                  Old guy
                  with a 4600kv motor, it surely isnt a 4s boat!
                  • old guy
                    • 687
                    #39
                    not sure if this will work. this was the vid he had on ebay were I got it from. this video you will see it go, I put a little bigger prop on it and on glass water it was way faster
                    old guy
                    • hydromaddicted
                      • 83
                      #40
                      old guy
                      Something hear does'nt add up;-)
                      • Simon.O.
                        • 1521
                        #41
                        Not wise but doable.
                        I have a 22" tub rigger that has a 7S-5070kv can that I once fed with 3S to the 432 prop for low to mid 40krpm at the prop
                        What is being suggested above is good for low 50krpm at the prop and there is no surprise that he blows carbons at those rpm. I blow them at 40odd krpm. Given they are suggested for up to 25krpm then we are all having fun.
                        Some guys use high rpm for speed and some go for prop dia. I like rpm. It sounds nice.
                        If the you-tube vid will ever load then I may get to see his boat doing its thing, for now I believe him.
                        • Ub Hauled
                          • 3031
                          #42
                          I like RPM as well Simon, actually, I like a happy medium between the high rpm and a decent size prop... I am still experimenting with it to find the happy medium.
                          • Simon.O.
                            • 1521
                            #43
                            This is about to go off the original topic and may need a new thread. Non GPS tuning methods There ya go Jan, you can start that one !!
                            I do a lot of my tuning by eye, ear and finger, ( cooling )
                            If it sounds like it is screaming, I smile and feed in more prop and watch.
                            • Ub Hauled
                              • 3031
                              #44
                              I was merely agreeing w/ Simon but I can see where how can stray, sorry everyone.. back to topic...
                              • damfurst
                                • 261
                                #45
                                These are the micros I have.
                                MHZ Gecko,13 1/3in long
                                has been ran with 7.2 Nimh packs, but mostly 9.9v A123 1100mah. On 11.1v 1300mah 22c is like a rocket. Motors have been stock Black Race Viper, 3800kv Emp brushless and currently 480 Mig brushed (just for the winter months to run on the creek) 2.4 Tactic radio, Running Gear is all MHZ stock, original flex cable replace with 2mm shaft which freed up this boat immensly.
                                Minicat Racing Micro Hydro
                                All stock though current motor is 3800 Emp brushless w/25a Scorpion ESC w/pistix. Battery is 11.1V 1300mah 22c Desirepower lipo.
