Mini Dom or ten shock Mini Scord questions
  • Froggy
    • Mar 2023
    • 125
    For you guys running these boats what kind of life expectancy do you get out of your shaft and bearings and what are you using for lube and how often do you lube up.
    Also what prop do you like the best for just bashing around, I purchased a Oxidean 32 1.4 pitch I wanted a 1.9 but they were sold.
  • Turbinator
    • Jul 2023
    • 4
    https://www.amazon.com/dp/B0951YR1SV...roduct_details
    https://www.amazon.com/dp/B085DMWHGB...roduct_details
    https://www.amazon.com/dp/B08F2HPLG3...roduct_details
    https://www.amazon.com/dp/B07MFTBHDZ...roduct_details
    There. The secrets out. Build your own oxxidriive. The tubes are 250mm.
    • Turbinator
      • Jul 2023
      • 4
      Pull the drive out after a few runs.The tubes will collect water. Drain.. A drop of oil on each bearing and shove it back in. A bit of a grease "packing" at the aft end to help keep the water out and youre good to go.
      • JoshuaCrump
        • Apr 2024
        • 1
        Are the products here genuine and warrantied?
        • Turbinator
          • Jul 2023
          • 4
          Bill, They every bit as genuine as yours.
            • 4335
            • Froggy
              • Mar 2023
              • 125
              I’ve purchased 3 of them from Tenshock they are exactly the same, just like Dymotorshop is the exact same Dominator.
              these hulls can all be purchased on Ali Express also for a 1/3 the cost never had a problem my DY motor shop hull came in 5 days to Arizona
              • Riversidedan50
                • Feb 2025
                • 48
                Been having a blast with my minidom , bought it used and complete with another minidom hull.......3S 2200 STOCK PROP /MOTOR AND ESC
                been lubing the prop drive after every 2/3 runs........BTW the spare yellow hull I have is up for sale. only thing thier is the empty drive tube rudder and motor mount
                PM for info
                • Itainteazy
                  • Aug 2025
                  • 1
                  I tried to buy a mini dom but waiting 6 months and it still never shipped out is a little too long of a wait for me. Anybody else have similar issues?
                    • 4335
                    Consider that a blessing in disguise, allowing you to avoid doing business with that guy.
                    • Riversidedan50
                      • Feb 2025
                      • 48
                      Ive had that same funny feeling about that outfit too, but not knowing any better yet picked up 2 minidoms
                      earlier this year dirt cheap that got me into model boating again,........ as for experience with that outfit I have had none. except thier used boats that run great......
