Mantis 18 in sport catamaran
  • Kitkid73
    • Jan 2023
    • 4
    Hi guys I'm building this boat its 17.9 in long, and welcome any suggestions for the drive to use, Steve has helped a lot, it's all balsa except a few choice parts are plywood
    Any pics of it. Scratch build is very cool
    Shawn
    • a53hoop
      • Oct 2019
      • 70
      could you tell me were i could get plans for this boat tks AL
      • Kitkid73
        • Jan 2023
        • 4
        Just search for Mantis on the Aerofred plans sight, that's where I git it, has the build article also, I tried to upload it here but couldn't for some reason
        Darin
        • Kitkid73
          • Jan 2023
          • 4
          To download from Aerofred, you have to register, but it's well worth it, a lot of boat plans. If someone could tell me how to post the plan and build article here, I would gladly do so ��
          Darin
          • a53hoop
            • Oct 2019
            • 70
            thanks for your info. lots of pans. have downloaded
            • Kitkid73
              • Jan 2023
              • 4
              No problem, now I just need a building board lol
              • Paringa
                • Mar 2022
                • 6
                You can also check on eBay..
                • NativePaul
                  Greased Weasel
                  • 2770
                  I don't know that particular boat, but I have build a number of cats around the same size at 450mm.
                  My go to power system for them is a 28x36mm motor of 3000Kv, 30-50A ESC, on 3s 1500-2200mAh, with a 1/8" flex shaft on a 4mm stub shaft (either threaded M4 or stepped down to 1/8" for dog drive), props in the 27-31mm range, 55mm rudder.
