helip on 19 in mini hydro
  • a53hoop
    • Oct 2019
    • 70
    i found a set of drawings on a site i have since lost. this is a kneeler style 3 point boat and i have a ose mini outboard question is proper depth to mount motor. the other thing is with battery and speed esc placed fully forward i will need about 8oz balast in the nose to balance on rear of sponsons.where would be the correct cog on this type boat. tks AL
  • NativePaul
    Greased Weasel
    • 2770
    I don't know that specific boat, but the bottom of the strut level with the bottom of the sponsons, and CoG 10-15% of the afterplane behind the sponsons wouldn't be a bad place to start.
    • a53hoop
      • Oct 2019
      • 70
      thanks for the help but bieng new to this not sure what afterplane behind the sponsons means.tks al
      • NativePaul
        Greased Weasel
        • 2770
        The afterplane is the area between the plaining surfaces, so the distance from the back of your sponsons to the prop, you typically want the CoG at 10-15% of that distance as measured from the back of the sponsons.
        • a53hoop
          • Oct 2019
          • 70
          thank you very much for your drawing and info. this should certainly help with my balance .tks AL
