The Evil Doctor's Next Project
  • Dr. Jet
    • 1759
    In my "Who wants to build a semi-scale........" thread, someone asked "What's next?" and I mentioned a mini outrigger. With some very much appreciated input from NativePaul, I revised the preliminary design sketches to fit European Mini Naviga Hydro rules (easy enough )
    I'm posting this thread to discuss my new design concept, based on the KEPS outrigger with the design philosophy of maximum weight reduction. If successful, I think I'll call it.........
    The Mini Me
    A nation of sheep breeds a government of wolves
  • Diegoboy
    • Mar 2007
    • 7443
    Bill,
    Any thoughts on pushing the forward sponson boom ahead of the tub?
    This could eliminate one sponson boom from the tub and make the boat run like a larger boat in chop.
    • NativePaul
      Greased Weasel
      • 2770
      Too late Dr. H&M's mini hydro is called the Mini Mi to go with their Dr Evil hydro1 and Dr Super Evil Hydro2.
      Only extending the afterplane length can make it run like a larger boat, pushing the front boom forward of the tub mainly gives you an easy way to adjust the angle of attack.
        But, moving the sponsons forward of the tub increases the distance between the sponson transoms and the prop - “lengthening” the effective length of the boat. I first saw this at the 2001 LA SAW race on one of the JAGs riggers.
        • Dr. Jet
          • 1759
          Originally posted by Diegoboy View Post
          Bill,
          I thought about that but I'm already at 449mm from tip of sponson to transom. Any longer and it wouldn't work for the European classes, AND it's already a pretty tight fit for all the gear that has to go into it. That would also add to the parts count and complexity plus I'd have to add structure (weight) to support the cantilevered boom arms.
          I know this composite one (see photo) uses that approach, but such are the shortcomings when working with flat sheets of wood. In all honesty, I doubt ANY wood boat would be competitive against lightweight CF hulls like that, but some people still like to dabble with wood. The cost for wood will be considerably lower though. I planned to include a laser-cut turn fin as well, but I've been informed that water-jet is better suited to cutting metal parts.
          If you look at the right sponson in my wire frame drawing, you will see I made the "handle" a bit longer to accommodate holes on either side of the sponson boom. I plan to put 1/4" aluminum rods, bored and tapped to 4-40 into these holes to hold the turn fin. I'm even thinking of using a nylon or brass bolt in the forward one to allow it to shear off if it hits something.
          • Dr. Jet
            • 1759
            Oh cr@p........
            Maybe I should call it..........
            • NativePaul
              Greased Weasel
              • 2770
              I have several boats like that,and know what you mean, but when you are already at the maximum hull length allowed, as in this case, all it does is shrink the tub and allow you to adjust the AoA easily.
              Dr. Jet
              That is tip of sponson to transom, right? The stinger doesn't count in overall length?
              Yes 450mm max from tips of sponsons to end of transom, ski, rear sponsons, or anything else that you could consider hull.
              I currently have it planned to run 2S, but if I stretch it, I suppose the extra 7mm would accommodate the Zippy 3S. Can you send me a link to the limiter?
              I didn't know you planned on 2S, in that case the KV of the second motor is too low, both 2s and 3s are allowed in the class battery weight limit for either is 113g inc 30mm of wire and connectors, which is currently 2800mAh for 2s and 1900mAh with 3s using the best cells, those using limiters aren't restricted to batteries, but about 140-160g is pretty usual. This is currently the only limiter that is really suitable for Mini Hydros, Wozniac has some being beta tested at the moment, but are not released yet.
              The sponsons will be hollow in the middle. They'll need skins for strength and water-tightness. Like the KEPS, the sponsons will have a plywood (or G-10 or CF or aluminum plate) for a ride pad.
              I get that, I was just thinking that if you flip the sheets 90 degrees, one of the skins you need for water tightness could do double service as the ride plate to save a little weight.
              Remember, my plan was to run 2S. I like the helicopter outrunners in the small boats for a couple of reasons. They have built-in fan cooling, and they have an order of magnitude more torque than an inrunner of the same size which means a bigger prop or more pitch.
              The torque difference between an inrunner and an outrunner of the same mass and KV isn't much at all in normal use, the only time it is worth mentioning is on startup when the extra poles give the ESC a much easier time. We run both and for our racing the prop sizes are what you would expect from the KV for either type. There is an advantage in the opposite direction to inrunners at higher power levels when water cooling beats air cooling in confined spaces and allows the inrunner to spin the bigger prop. Much more noteworthy advantages are the typically better efficiency and much lower inertia of an inrunner vs the weight savings of not needing a water cooling system.
              I looked at the RBC Fast4ward. It reminds me of the old adage regarding aircraft origins (see photos): If it's ugly, it's British. If it's weird, it's French. If it's ugly AND weird, it's Russian....
              What do they say if like the Fast4ward it is Dutch? It does look pretty bizzare, but steepening the sponson tip to sponson transom is the only way to increase the afterplane lenght with a maximum hull length, and they have taken it to the extreme, a little too far I would guess, but I've not seen one run.
              Instead of a strut with beefy mounting brackets. I'm using a fixed stinger.
              We don't really use beefy mounting brackets, it is usual to use a couple of strips of carbon sheet let into the transom to hang the rudder and strut from.
              The 1/32" wire drive I like is a whole lot lighter than 0.098" cable, but I'd need to do a lot of testing to see if it would hold up to 3S over time. It works just fine with 2S boats, but I haven't used it for 3S. 1/16" wire should work as well, but I think in these small boats puts a lot of radial loads on the system. As long as the motor and propshaft use decent ball bearings, it should be OK.
              I haven't seen anyone using a flex in a mini hydro for quite a while, i think wire run more freely, but even if they don't the weight penalty of the flex and full length stuffing tube that it needs is too much to overcome. we typically use 1.2 or 1.5mm wire, 1/32 is 0.8mm. I have not used that small but I have used 1mm in the past and it held up fine, but due to drill and ream flex the guy that made my stub shafts said that it would be the one and only he would ever do. I think you build your stubs out of telescoping tube, but the telescoping tube I have used in the past hasn't been close to tight enough to ensure good enough alignment and runout for me to be comfortable.
              • NativePaul
                Greased Weasel
                • 2770
                I know this composite one (see photo) uses that approach, but such are the shortcomings when working with flat sheets of wood. In all honesty, I doubt ANY wood boat would be competitive against lightweight CF hulls like that, but some people still like to dabble with wood. The cost for wood will be considerably lower as too. I plan to include a laser-cut turn fin as well.
                That composite one is Mila Holc's Agulya (spelling) splashed, it is about a 15 year old design from well before the class existed, it is under 400mm and the makers just added the arms to bring it up to 450mm and make it vaguely competitive in the class rather than designing something themselves. For what it is worth my latest kevlar moldie was aprox 1oz per sponson and 2oz for the tub (sealed but unpainted). I wouldn't use a nylon bolt on the turn fin, our turns are tighter than American ones at a 5m radius, so there is quite a load on the turn fin, and that load has quite some leverage on those bolts. Use 3mm boom tubes and they will be sacrificial enough.
                • Dr. Jet
                  • 1759
                  .......... I think you build your stubs out of telescoping tube, but the telescoping tube I have used in the past hasn't been close to tight enough to ensure good enough alignment and runout for me to be comfortable.
                  I did that once as an experiment using 1/8" SS tube. The tube was actually about half a thousandth too large in diameter and I spent a lot of time sanding it to the proper diameter to make it work. Normally, I use Jeff Wholt's stub shafts that are drilled for 1/16" wire (that's what's in the Atlas kits - See photo). I have found a source for very precise 1/16" O.D. 304 stainless steel tube with a .08mm I.D. I use Loctite green to attach the wire to the SS tube, then again to the stub shaft. So far, it has worked flawlessly in other applications.
                  ....... I didn't know you planned on 2S, in that case the KV of the second motor is too low,....
                  I know. I'd like to find something in the 4400 to 4800 Kv range, which is why I mentioned that little 4900 Kv motor. I think it is physically too small though, and while being lighter at 45 grams, it may not have the "oomph" necessary. I did order one so I can give it a try though, as it is half an ounce lighter.
                  Remember, I'm just going to run some circles at the local pond for ships and giggles and trying to do it on the cheap. I'm never going to enter any organized racing with anything I build. If I were racing in your classes, I'd use a state-of-the-art carbon fiber hull with an 1105 3Y on 3S or an 1105 4.5D or 2Y on 2S.
                  That composite one is Mila Holc's Agulya (spelling) splashed..........
                  I wasn't making any recommendations, just pointing out an example.
                  ..... What do they say if like the Fast4ward it is Dutch?
                  I thought RBC was a British company. Maybe the design is Dutch.
                  • NativePaul
                    Greased Weasel
                    • 2770
                    Originally posted by Dr.Jet
                    I have the drawings for the 449 mm outrigger finished and I’m ready to cut a couple plus enough additional 1/16” ply parts to fill out the remainder of a 12" x 24" plywood sheet. I plan to build one and only one for myself as a prototype. The additional parts will go into storage as I have no plans to purchase and cut the materials necessary to complete any additional kits at this time.
                    If you are cutting a couple, but only building 1, does that mean you are selling the other one, hint hint?
                    • Dr. Jet
                      • 1759
                      Since you've been super-helpful with my projects (and I do appreciate it), I will see that you get one "At my cost (plus shipping)". It may be the only other one in existence, but then again, you may have some more insight that I can incorporate into future designs that might sell enough to make............
                      • Dr. Jet
                        • 1759
                        1/32" Wire Drive
                        I'm fond of the 1/32" wire drive for the little boats because it's simple, it's cheap, it's light weight, it's easy to seal, and it doesn't put a big radial load on the bearings.
                        I run the 1/16" stainless steel tube bonded in the propshaft past the 3/32" brass seal tube on the forward end of the stinger. From there it's bare wire until the motor coupler where there's another short piece of 1/16" SS tube to give the coupler something to grip. Sealing it is easy; just a medium coat of grease on the 1/16" SS tube where it goes through the 3/32" brass tube seals everything up. I use this exact arrangement on the Twin Micro Scat Cat and never get a drop of water in it. I can always put a piece of silicone tube on the 3/32" seal tube to seal against the 1/16" SS tube if there ever were a problem.
                        • NativePaul
                          Greased Weasel
                          • 2770
                          Thanks Dr.Jet that is very kind of you, let me know where to send the money when you are ready.
                          Do you have the stuff needed for another one of those drivelines too? I would like to give it a go, but think I would have trouble finding the imperial sized parts here, all the fractions are making smoke come out of my ears just getting my head around it, no worries if not, I have 1.5mm wires on hand.
                          • Dr. Jet
                            • 1759
                            I'll make you one of the little drivelines as well, including my custom-machined end seal. I'm thinking of making the stinger out of aluminum tubing instead of brass to save a gram or two. What's your preference?
                            • Dr. Jet
                              • 1759
                              Thanks Dr.Jet that is very kind of you, let me know ....... when you are ready.
                              I may have stuff to start as soon as this Friday. The laser guy has the wood as of Tuesday, April 2, 2019. I want to build a prototype first to make sure it's right before sending any parts to you. Stay tuned.....
