testing a motor
  • heyjack8
    • Oct 2018
    • 45
    testing a motor
    ok I sunk my Mini mono I wanna test the motor with a new ESC to see if it still works...is there any risk to the new ESC if the motor might be damaged..? comments appreciated...
  • longballlumber
    • 3417
    Assuming that you sprayed out the motor with WD40, Isopropyl Alcohol, RC Car Motor Cleaner, or CorrosionX then re-lube the bearings with oil, the risk is low.
    Good Luck
