drive line stuffing
  • heyjack8
    • Oct 2018
    • 45
    drive line stuffing
    found this little plastic piece hiding in my miscellaneous drawer ...put it on the mono stuffing tube on the inside after a run nothing bone dry like a desert....poked a small hole through to accept the wire and packed it with grease as well...IMG_1523[1].jpg
  • martin
    • 2881
    Yes that is a pretty common mod to stop water entering the hull, some use the method you have used. You can also use heat shrink tube or most use a piece of silicon water tube esp if its on a flex cable.
    • heyjack8
      • Oct 2018
      • 45
      yes I agree I just didn't have the right size in my inventory of heat shrink...
        • 4340
        I use automotive vacuum caps like that on stuffing tubes with wire drives.
