I made a new nose cone for the strut that will go on this hull. As you recall, the last one did not have the bore for the shaft concentric with everything else. This was due to run-out in my lathe chuck and the resulting inability to clamp the work piece in the same place after removing it from the chuck.
I replaced that old chuck and the difference is astonishing. The 1/16" hole bored through the entire thing is centered to well within 0.0005".
The drive on this will be very similar to the one on the little Casper hull with the exception of I will be using 1/32" music wire instead of the carbon fiber rod. The steel wire will be able to handle the increased power with ease. I've proven it with the BBY Micro Scat Cat.
What to do?
Upon inspecting the piece, the hole on the backside looked to be about 1/8" in diameter.
I took an old broken Dremel grinding wheel that was just the shaft and crammed it in the hole. Behold! It fit!
Looking at the precision-printed kits got me to thinking..... Why am I fooling around with gluing, sanding, sealing, and finishing wood bits, when with just a little design work, I could make a PERFECT 3-D printed hull with all the required motor, servo, and hardware mounts already built in?
