Venom rc boat with brushless motor park puddle
  • silencespr
    • Apr 2017
    • 22
    Love my park after rain makes some fun puddles with trees and lots of water.
    Upgraded my cheap venom boat with 2300kv drone motor, 10amp esc from a broken drone and 3s 1050mah battery got good 30 min run out of it.
    • 4338
    Does it still self right? I've got a Venom that my kids have outgrown and Dad always needs a new project! Can you post a picture of the inside with the new parts installed?
    • silencespr
      • Apr 2017
      • 22
      This run it did not because I placed 3s in the front of the boat, this was my 1st run I just placed the battery above the motor inside the cabin and it fits perfectly. Will go in a few again and test if it will self right. Boat is 60 grams lighter than stock and way way faster. I have two one has a brushed motor upgrade faster than stock buy a few miles I'll run them against each other to see how much faster this one is. I like this boat more than any boat I own because how cheap, reliable, strong and agile it is. I was surprised that after 30 minute run motor and esc got berally warm with out any water cooling.
      Because I didn't want to waste any money upgrading this I used spare parts from a drone the 2300kv motor fits perfectly in to original motor mount if it gets pushed back a little, entire nose is empty space now perfect for a flotation foam.
      Pictures
      • silencespr
        • Apr 2017
        • 22
        • silencespr
          • Apr 2017
          • 22
          i will put a timer and time exact time this battery lasts me.
          • silencespr
            • Apr 2017
            • 22
            i can't get it to self right wonder what i need to do... it does swim upside down from the prop pushing against the wind haha.
            • silencespr
              • Apr 2017
              • 22
              Ok I was able to make it self righting again by pacing battery closer to the hull wall offsetting the balance. It's a bit nose heavy but under full throttle it stays well above water.
              • silencespr
                • Apr 2017
                • 22
                Because the battery is up front the boat get off the line slow and fills up with water even if I have tape all around, need to find better solution to water proof it maybe the hatch tighter. When water fills up the boat no longer uprights.
                Here is a video of a little race at the puddle brushed boat has upgraded brushed motor and is faster than stock.
                • silencespr
                  • Apr 2017
                  • 22
                  Found some smaller sized lipos will see how well it does on them much more room now whole front is empty.
                  • silencespr
                    • Apr 2017
                    • 22
                    I was able to fit everything back in original places think self righting should work perfectly now.
                    • silencespr
                      • Apr 2017
                      • 22
                      Put in 1800KV motor but bigger size and boat now flips over with out any issues.
                        • 4338
                        model number?
                        • silencespr
                          • Apr 2017
                          • 22
                          model number?
                          Armattan 2822/12 1800kv
                          • silencespr
                            • Apr 2017
                            • 22
                            Taking out these boats against my stock atomik barb wire lets see what happens in straight line.
                            • silencespr
                              • Apr 2017
                              • 22
                              ran it against my stock barb wire and off the line it puts good 20 feet on barb, because barb takes a while to get out of the water, full out throttle its about 5mph slower but its is extremely stable.
