While I'm working on this and several other concurrent projects, I thought I'd share some thinking and future plans. Obviously, the laser-cutting is aimed at the "kit" market. What is the market for a kit-built, all-wood Mini Fast Electric catamaran? I can count interested parties on one hand and have fingers left over. Still, I like the idea of saying "I designed that"...... Yeah, the basic idea was provided by someone else; but the fine-tuning and laser-precision was my doing.
I chose a power system for Prototype #1 that had a fairly high Kv (and thereby a fairly low Kt) for the first iteration. The Aveox motor I selected likes a small, cut-down X427 prop. A bigger outrunner of somewhere around 3800~4000 rpm/V with a bigger prop might be a better choice for this hull. Testing will provide the answers.
I've framed-up a prototype #2 for twin power, but it is currently at the bottom of my stack of things to complete. Prototype #2 used the original laser-cutting, but I made some modifications for the ride surfaces and the gunwales at the first two bulkheads. I think this will make for a better finished product.
I really don't need a cockpit on #2 since the motors are buried in the sponsons. I've also changed my choice of motors and props for a number of reasons, primarily because I wanted motors with built-in fan cooling. This is the motor I'll be using:
It's a short can motor so I'll be a bit more conservative on props. I'll probably start with 32mmx1.4P counter-rotating props and keep a close eye on temperatures for the first few runs. I will reduce the prop diameter if things get a bit too warm.
, and to Jesse J
