Largest Motor/ESC Combo In JAE Mini Sprint
  • jim82
    • Jan 2013
    • 1358
    #121
    If not I a 120 sk v2 that may work what is you thoughts
    • jim82
      • Jan 2013
      • 1358
      #122
      Will one of the new 60 t/sk esc's work with out moi=ods being made?
      • jim82
        • Jan 2013
        • 1358
        #123
        Will one of the new 60 t/sk esc's v3 work with out mods being made?
        • NativePaul
          Greased Weasel
          • 2770
          #124
          I would imagine so, never used one myself though.
          • riversidedan
            • Aug 2015
            • 103
            #125
            Grease the tube??
            we got the motor in and when I run it up the shaft sounds like its hitting the stuff tube , do I need to grease the shaft??
            BTW how big is the lipo and where exactly does it fit in the boat? I ask cuzz the stuff tube is sticking up a bit where the lipo needs to go, am thinking I need to make some kind of shallow platform to sit the lipo on?
            • jim82
              • Jan 2013
              • 1358
              #126
              You always need to grease the whole flex shaft or wire no matter what you use. If you have no teflon liner in the stuffing tube it will still be louder no matter how much grease you use.
              • riversidedan
                • Aug 2015
                • 103
                #127
                thanx!
                • jim82
                  • Jan 2013
                  • 1358
                  #128
                  Well, guys I got a chance to work on the boat today. I was able to get the stock cooler on the motor (leopard that is) and it's clearing the cowl without any mods. I am using a SK120 but had to take cooling block off to make it fit (not sure if it will stay cool enough but we shall see). I had to do that to allow room for the lipo. I am hoping to get it up and running by this weekend and if I do I will post some pics.
                  • SweetAccord
                    Speed Passion
                    • 1322
                    #129
                    Would love to see pics.
                    • jim82
                      • Jan 2013
                      • 1358
                      #130
                      • SweetAccord
                        Speed Passion
                        • 1322
                        #131
                        Nice, what prop you plan to run?
                        • jim82
                          • Jan 2013
                          • 1358
                          #132
                          Stock till I get her dialed in and see what the temps are. I hope to get the y536 in for speed runs. Haven't had much time to mess with the boat lately due to work but I will keep you guys updated as much as possible. I am going to only run her on 2s for now being its a 4700k motor. I may then try for a couple 3s passes.
                          • jim82
                            • Jan 2013
                            • 1358
                            #133
                            On 3s the sponson with the turn fin is lifting out of the water any suggestions?
                            • NativePaul
                              Greased Weasel
                              • 2770
                              #134
                              Tilt the bottom of the turn fin back a little.
                              • jim82
                                • Jan 2013
                                • 1358
                                #135
                                Did that already I am going to try all the way as far as it will go thanks paul
