DF23 prop shaft
    • 9481
    DF23 prop shaft
    Looking for the stock prop shaft or something that will bolt right in to my DF23
    the one I own has a slight kink in it and I should probably replace it since I am going 6s in it
    any and all help would be appreciated
    • 9481
    Anybody .....
    #9,000 post
      Anybody .....
      #9,000 post
      P.S.
      sorry sir, I can't help you with the shaft. Just want to say cheers for your dedication and consistency on the Forum!
        Can't remember its size, sorry.
          I have drilled out the DF23 strut and used octura lead Teflon so I could use standard off the shelf shafts. You have to use a drill press and carefully one drill bit at a time with some lube for the drill bit.
            • 9481
            P.S.
            Awesome thank you
              • 9481
              Oh man, that sounds like work.. LOL
              but a good solution
              soon as I get the shaft figured out I am going to post a build showing what electronics I'm using, and I have a very strong feeling you all are going to like my power selection
              • iratner
                • 31
                DF23 prop shaft
                I am also looking for DF23 prop shafts and have asked Steve V. to contact Delta Force and they have agreed to make a supply for us. I informed Steve of your request and he will contact you when they come in. It should be in another 2 weeks.
                  • 9481
                  awesome !
