Jet Sprint build for Boondal Class. ( Glass Hull)
  • Mad Racer
    • Nov 2013
    • 140
    Well this will be my 2nd Jet sprint for the Boondal controlled class.
    My first one is the same glass hull but is running a 2960 2200kv brushless set up as I burn't out 2 brushed motors for some reason. So it's not legal and while it's a fun class the brushless set up has way more torque.
    This new hull is to the Boondal spec's but with water cooled brushes and a esc fan on the motor. Glass hull is from Damien from Boondal and you can buy it all in kit form from him and Ray. So lets have another shot at it.
    Spec's are.
    Hull .......................... Fiber glass
    Hatch Cover................Fiber glass
    Rudder with pick up.... Hobbyking TFL
    Shaft.........................4mm flex
    Stinger Strut.............. TFL with custom brackets
    Prop..........................Graupner 2 blade 4056
    Motor.........................Great Planes ElectricFly T-600 9.6V
    Motor Mount................ Etti 540 mount kit
    Water cooling kit.......... TFL
    ESC........................... Blue brick Boat esc waterproof
    Battery...................... 2200 3S Li Po
    Servo......................... Standard Type
    Driver Figure............... Tamiya Fox
    V8 engine................... Chrome E Bay special
    Spec's can vary a little but the Motor , Prop and battery are controlled for close racing.
  • Fella1340
    • May 2013
    • 1025
    Cool boat, you may want to move it over to the build section for more responses and views. I'd like to see more of it. Good luck!
