Atomik barbwire prop and motor upgrade?
  • shartinspartin
    • Aug 2013
    • 257
    Is there an upgrade prop and motor for the barbwire?
    Thanks
  • MassiveOverkill
    • 139
    The motor can't be upgraded without ripping out the current motor mount and glassing\epoxying in a conventional one. The ESC is on the verge of blowing with the current setup so a larger one (35 Amp.......no larger as this boat is weight-sensitive) would be required. Other's have tried difference props with success but you'll have to do a search.
    • nemz305
      • Jul 2013
      • 42
      x632 prop
      • romanr
        • Dec 2013
        • 9
        Octura X432 balanced and sharpened. You will want to step up the ESC. I'm running an Atomik Pro Brushless Marine 50 Amp ESC with great results.
        • CWBETB
          • Dec 2013
          • 43
          Happen to have any vids with upgrades? Thanks
          • romanr
            • Dec 2013
            • 9
            Here are two.
            • Southwest
              • 274
              • CWBETB
                • Dec 2013
                • 43
                Watching those vids makes me miss the warm weather! :)
                Looks pretty good! Ever run anything to test speed on it vs stock? I found some speed test apps for a cell which would work well...just dont know how i feel about strapping phone to the boat haha
                • Fella1340
                  • May 2013
                  • 1025
                  if your not into doing upgrades the minimono out of the box with a good lipo and prop wouldn't be much slower than the hopped up barbwire. it surprised me everytime I drove it. add a 3800kv motor and it's insane (with seaking 35amp esc). if the minimono was selfrighting it would be the winner to do it over again I would get the barbwire because the do flip and roll a lot. Both are nice little boats. My son loves his.
                  • Fella1340
                    • May 2013
                    • 1025
                    sorry, posted in the wrong thread! I wouldn't have thought that possible...... Ignore the above please and try to overlook my stupidity.
                    • Norwest
                      • Mar 2014
                      • 165
                      ////// Wrong thread..
                      • shartinspartin
                        • Aug 2013
                        • 257
                        i use 2200 mah no problem without dremeling...
                        • Tharr62
                          • May 2014
                          • 42
                          Will the stock ESC that ships with the boat be okay with this prop? I got the boat yesterday. Also, I see that you ran some thunderPower 2700's?? wow. What was your run time, and did the boat right itself okay with the added weight? Was it slower with more weight at all? Thoughts?
                          • stadiumyamaha
                            • 1284
                            I've run 2200mah batts and the boat is much slower with them and isn't as fun to run. It works and runs longer but handles poorly. The biggest problem I've found is the stock esc's lvc is set way to high. When it cuts in my batts are still at 3.9 per cell.
                            • shartinspartin
                              • Aug 2013
                              • 257
                              what llipos are you using? The turnigy 2200s im using add weight. But doesnt really affect handling or speed..... The extra time was def. a +. It still even self rights with the bigger lipos....
                              Also my lvd cuts in at 3.4-3.6 on mine from what i remember. Sometimes lower. Do u have the v1 or v2 esc?
