Barbwiire or MiniMono Stock - Advice for a Newbie
  • Talan2000
    • May 2013
    • 6
    Hi Guys,
    I'm new to RC in general and brand new to RC boats (first post!)...stepping up from a sad little Zig Zag Racer 3 whose motor is rusted and waterlogged but who still chirps away optimistically for a few minutes...anyway, as a newbie I've been lurking and reading and watching videos.
    I know I would love to have a Revolt 30 -- eventually. But 300 is a bit too much right now - especially as one gets sucked into all these myriad upgrades and the headaches they bring to a newbie. And I really would prefer 10-15 minutes of driving around rather than 2-3 minutes of straight line speed then...recharging..
    So - I think I've narrowed down my first real boat choice to ... the MiniMono OR the Barbwire (which I just stumbled upon in the forums). I like the idea of brushless motors and LiPo.
    My usage will be on freshwater ponds varying from small (50x50yards) to medium size (100yds by 50yrds wide say). I'd love to be able to use LiPo instead of NIMH or other batteries to leverage my investment from RC car batteries.
    which of these boats would you recommend given my usage goals? Or would you say save up for a Miss Geico 24 (or 17) or Mystic or Motley Crew or UL-1 (I read that poll survey of 1st boats :)
    Thanks in advance - and any other advice about changing out the drive (?) in either option or other easy & cheap upgrades to Mini or Barbwire would be much appreciated (especially links!)
    Gracias
    Todd
  • Gabe_k
    • Jan 2012
    • 126
    the barbwire is all you need, you will not regret it
    • Gabe_k
      • Jan 2012
      • 126
      I have a MG 29, UL-1, Mini Mono and a few others, the barbwire is by far the best bang for your buck. (I drive it the most as well)
      • jetskier
        • Jan 2013
        • 230
        Barbwire!!! Atomik hit the jack pot on this one.
        • Talan2000
          • May 2013
          • 6
          Thanks guys. As is often the case in RC world. I ended up burning 300 anyways! Bought a blemished atomik whiplash for 149 and AFTER seeing your responses felt COMPELLED to buy the Barbwire! :)
          • Talan2000
            • May 2013
            • 6
            As a follow-up (and cross posted in the battery section), what batteries would you recommend for the Barbwire and for the Whiplash 24? I'm getting confused by all these various connectors. I have traxxas connectors now on my Onyx 245 charger and want to use that charger. Is there some adaptor that goes from HT-60 ends of Zippy Batteries. Should I just get Venoms (@4x the price!) and what run times should I expect for recreational use from 1300mah or 2200mah 20/25 c batteries
            • jetskier
              • Jan 2013
              • 230
              Barbwire comes with it's own battery 3S lipo 1300mAh w/universal adapter. I just bought 2 more of the same. they are good batteries and will work with any lipo charger IMO.
              • Gabe_k
                • Jan 2012
                • 126
                have you never used a soldering iron? lol
                • jetskier
                  • Jan 2013
                  • 230
                  Smoked my 3rd ESC 2 on my first Barbwire which is now my son's, and this one on my new Barbwire. have to admit.. I run them hard during my lunch break, 3-4 batteries continuously. they replace 2 no question ask, we'll see about this one.
                  • Talan2000
                    • May 2013
                    • 6
                    Wow. so not to be dense, but what exactly are you doing to fry these? holding full throttle for 5 minutes plus? And thanks for the tip Gabe, I'll look up this "soldering iron" you refer to...that said I think the point is how to standardize connections and which one to select, but thanks for the feedback.
                    • Gabe_k
                      • Jan 2012
                      • 126
                      full throttle is actually the easiest on ur esc.. its when you blip the throttle a lot that heats it up. I put deans on every single rc I own. I would never run stock connectors. Quality bullet connectors are best though.
                      • jetskier
                        • Jan 2013
                        • 230
                        I run them full throttle and non stop except battery swap. I think what kills them is. When they sub the prop gets unloaded the loaded. Enough times and full throttle, They just craps out. Funny.. All 3 ESC happens differently. This one is the worst, it poped out of the water a d it stop. The first one, I remember I was on my 3rd battery, put the boat in the water, give throttle and it just died. They are so fun, you can't not abuse them. With my Revolt, I'm much more careful.
                        • Speedracer128
                          • Apr 2013
                          • 288
                          I bought a barbwire for my 4 year old. It's awesome and he can have fun when we're out on our boats. The thing is so fun I use it myself and bought some plastic octura props but I don't know if they make much of a difference
                          • Speedracer128
                            • Apr 2013
                            • 288
                            Has anyone seen one of these barwires moded besides changing the prop? I'm more than happy with its performance but I'm interested if anyone's tried any inventions with it
                            • jetskier
                              • Jan 2013
                              • 230
                              1. I poked another hole on the steering servo horn closer to the shaft, it turns too sharp stock and was tired of the right turn sub. now it handles much better. 2. Sharpen the rudder and turn fins for cutting through weeds. 3. added a little more weight to the battery side and now it self upright 100% and also helps with not subbing on right turns. That's about it. thinking about bending the stuffing tube so the drive line is more straight and not pointing down, it's got a flex cable drive line anyway. oh..I also sanded the bottom. didn't really notice any speed increase.
