So I bought one of these things soley so I can mess around with it in the pool. The speed is fine for now, I just want to upgrade a few of the weak parts. Everything I buy eventually turns into brushless stuff then goes way to fast and gets destroyed and I start back a square one. Therefore, this will turn into a speeding tcking bomb, but right now I want to upgrade the rudder assembly, battery, and props. Im not sure what the esc can handle, but a 3 cell wont work.. Heres the parts im looking at getting.
http://hobbyking.com/hobbyking/store...der_Small.html
Im not sure what the size is of the stock one but im fairly sure this should work?
http://hobbyking.com/hobbyking/store..._2S1P_45C.html
this bat should fit.
Now, I dont understand props at all.. the stock ones are 30mm. Im thinking i want a 3-blade prop for a little more torque? Im not sure if I can go up in prop size so can anyone help with some nice upgraded props that will make it run a little stronger? I want them to be metal to look nice with the rudder... can anyone point me in the right direction?
