HK New ECO
  • SweetAccord
    Speed Passion
    • 1302
    HK New ECO
    http://www.hobbyking.com/hobbyking/store/__25090__ECO_Fiberglass_Boat_Hull_530mm_.html
    N
    ew from HK a bare hull ECO. Unfortunately they don't carry any hardware for it.
  • cpgise
    • 90
    I ordered one a few days ago. I'll post some pics when I get it. Looks like you have a few minis. Any Eco builds? I'm trying to figure out where to mount the hardware for this hull. I found other Eco build but they all are shorter.
    • SweetAccord
      Speed Passion
      • 1302
      I don't have any ECO's. I'll see if I can find any info on ECO setups that may help out.
      • SweetAccord
        Speed Passion
        • 1302
        Ok here are some setups that may be close to what you may want:
        http://www.eco-idc.de/eco-news/einbau_marlin.gif
        S
        ome good links and discussions with pics:
        http://www.rumrunnerracing.com/feforums/showthread.php?t=31554
        http://minicatracingusa.com/images/instruct/miniecoinstruct.pdf
        Possible hardware: http://www.etti.com.hk/index.php?cPath=6
        Serrvo Layout:
        http://www.ec21.com/offer_detail/Sel...--9454727.html
        If you dont have it yet, you will want the Etti motor coupler that OSE carries as that is what I use on my other Mini's and they are awesome.
        http://www.offshoreelectrics.com/proddetail.php?prod=etti-a006
        Hope that gets you going!
        • cpgise
          • 90
          Nice. Thank you for the info. I ordered the etti hardware when I bought the hull. We shall see what the quality is. That's a interesting coupler. I missed that one on the etti. web site. I would have probably ordered it. I'm not a fan of set screws.
          • SweetAccord
            Speed Passion
            • 1302
            I've been there done all that, that coupler is best. What I had to do is use different size stainless steel sleeves that go over the motor shaft to make that coupler fit, but once you do that you will love it. It holds well and will not chew up your cable.
            • Gromov
              • Aug 2012
              • 49
              Hi Chris.
              What motors and batteries are you going to set your EСO?
              ecomaster.torgg.com
              • cpgise
                • 90
                Hi,
                I ordered this motor. http://www.hobbyking.com/hobbyking/s...r_2630kv_.html
                And for batteries I don't have nimhs so I was going to start with a 2s lipo. I have anywhere from 1.5ah to 5.0ah. What are your thoughts?
                • SweetAccord
                  Speed Passion
                  • 1302
                  Those are good motors! I have two of em. They are really Suxfly motors but the pic does not show that and HK put their logo in it. They are made by www.suxfly.com. That motor is rated at 14.8v 2~4s. 2s may be ok, but 3s should be a sweeter spot to run at for that hull size, and to get the most out of that motor but prop down as a start. 29000 RPM should not be too bad with 3s on that hull size but I think you can go more in KV. Here is video with similar hull in length with 4100kv motor on 4s.
                  With 3s maybe start with a 27mm and then try a 30 mm prop. and work your way up. You will likely need to use a 40A but that may be cutting it close, a higher amp like 50-60A or higher would be much better. Use whatever batter you have that is a highest C rating but is not too heavy, maybe start with a 2200mah to keep it fast and light, but if runtime is short go to higher mAH.
                  Some video's and other setups: (Hull: ETTI Tsunami)
                  Motor: ETTI 4100Kv, ESC: ETTI 90A, Lipo: 2s 5000mAH Flightpower, 30 mm prop. > http://www.youtube.com/watch?v=DmBQ2FweGwk
                  Motor: ETTI B29 4650kv, ESC: ETTI 90A, Lipo : 2S1P 5400mAh, 31 mm prop. > http://www.youtube.com/watch?v=K9REmORI_90&feature=related
                  Please keep us posted with your build. I have not found anyone who has one of these hulls and has posted what they have done with em. You may be the first, so it will be nice to see how it turns out!
                  • cpgise
                    • 90
                    It just shipped today! Talk about slow.
                    • SweetAccord
                      Speed Passion
                      • 1302
                      Jeeze. Yeah they are slow. I watched my order sit for a week and take a week to go out (all was in stock) before it hit the US customs and after that it was 2 days to my door. So it took 2 weeks and 2 days. Eh, for the price I can wait.
                      • SweetAccord
                        Speed Passion
                        • 1302
                        Did you receive it yet?
                        • cpgise
                          • 90
                          No . I have everything but the hull.
                          • SweetAccord
                            Speed Passion
                            • 1302
                            ugh...ok.
                            • cpgise
                              • 90
                              Got it today. I'll post pics later. The finish is a little worse than the one on Hk but overall it will be ok.
