What is the fastest mini these days? Cast your vote!
  • Chuck E Cheese
    • 2136
    mine was using a mamba 25 and df400 from the renegade rigger..... prop work and weight is key on
    these little riggers....
    see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
    • sailr
      • 7128
      Only 7 days to go to get 15% off purchase of $100 or more at Mini Cat Racing USA! PM me for details. We have the Mini ECO, Starship, Micro Hydro, and Velocity Cat in stock!
      Mini Cat Racing USA
      www.minicatracingusa.com
        • 9481
        Is this Eco mini fast enough for you ?
        http://www.youtube.com/watch?feature...&v=CGhMsoEDdlg
        Wow is that cool!
        • jlanders001
          • Nov 2011
          • 41
          What happened to the Micro-Bat?
          Been in RC for years. But have not tried all the types of boats.... YET!
          • jlanders001
            • Nov 2011
            • 41
            Originally posted by martin View Post
            This is my Mini Sprint with $12 Mystery 3800kv outrunner motor on 3s with 60 amp cheapo esc.
            http://www.youtube.com/watch?v=nOUlQEGC8lg
            What brand was the ESC that you used?
            • martin
              • 2881
              The esc was an RC Max 60amp watercooled which was £13 or around $20, i got it from giantcod.co.uk. I believe these esc are the same as the many cheapo different badge ones that are on Ebay under various names.
              • Mattwarner
                • Aug 2011
                • 495
                Does anyone in the uk stock the mini sprint, I want one now seeing this!!
                • martin
                  • 2881
                  You have to get them from Zippkits in the US, i believe they are doing them for $89 at the moment down from $109. When i got mine shipping was around $36 to the UK + vat & import duty. In total i think it cost me around £100 for the kit by the time i paid everything.
                  • martin
                    • 2881
                    If your going to push the speeds on the kit your going to have to do some mods, the rudder bracket is part of the ply side & you need to alter this to a full alloy bracket otherwise you tear the rudder off in turns ( ask me how i found this out ). The design construction was not done to suit these loads & speeds. Also you need to upgrade the carbon boom tubes which are 3/16" o/d hollow to 6mm solid carbon (again ask me how i know). Another must is bolt the turn fin right through the sponson otherwise youll tear the screws out of the sponson in the G force in turns.
                    • larryrose11
                      • Jun 2010
                      • 768
                      A moderator should take Martins notes / recommendations and make a 'sticky' for the JAE mini sprint, as a lot of people on here want to go crAzY fast. else, they will get lost.
                      FYI, a 3/16 of an inch = 4.7625 mm on the carbon booms.
                      • BILL OXIDEAN
                        • Sep 2008
                        • 1561
                        BBY Racing designs by far the fastest, most stable and reliable mini boats in the world hands down.
                        Randy has all the stats, ill get him to post when he wakes.
                        • martin
                          • 2881
                          The original boom tubes are 3/16 o/d tubes which will break if you push speeds, in the UK imperial size tubes or solid rod are not available only metric. Thats way i went to 6mm o/d solid carbon rod which then makes repacment easy without having to order from the US. Even on the JAE 21 fe during the build i change to metric size carbon boom tubes ie i fit 8mm & not 5/16".
                          • martin
                            • 2881
                            BBY does make some excellent boats but you wont get a boat complete (less motor & electrics )with all hardware for around $100, yes you have to build the kit which is dead simple & great fun to build.
                            • martin
                              • 2881
                              The 6mm = .236" solid boom tubes were chosen for their larger diameter + solid rod for the increase in strength.
                              • larryrose11
                                • Jun 2010
                                • 768
                                BILL OXIDEAN,
                                I have seen the BBY Lift-master rigger series only on this site. Awesome looking / running boat.
                                Randy had a pic of a small lift master in another build (the pink lift-master build)
                                Can you tell us more about this smaller of the lift-masters? Will it become available to the public, or at lease OSE members
