I have two boats using the same Tactiac radio, the ESCs are Seaking 35 and Seaking 90. When I program them they have the same problem: if I follow the instruction which is to set throttle trim, EPA, etc. to 100%, then they will not arm properly, next time I connect the batteries the motor spins mad. The only way I found that will work is to set the trim to minimum and then do the programing which allows proper arming. To get full throttle I wait until the boat is in water then I crank up the trim setting. Is this normal or am I missing something?
I hope I posted in the right place!
Tim
I hope I posted in the right place!Tim
