Small Bolt Drive Shaft Problem Advice Needed
  • CaptPJB
    • 276
    The flex shaft on my Small Bolt unraveled probably due to pressure from the set screw over time would be my guess.
    So do I just replace the flex shaft and if so where can I get one with the square end also can you just get the flex end or does the two piece unit come as a set?
    Or would it be better to upgrade to a single piece flex drive which would make greasing so much easier and if so what what do I need to convert and where to get it?
    Thanks in advance
    Peter
  • monojeff
    • Nov 2010
    • 2728
    Try this out http://www.offshoreelectrics.com/pro...oct-oc098L-24c
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • monojeff
      • Nov 2010
      • 2728
      Basstronics has couplers he is selling to work with stock engine.
      http://forums.offshoreelectrics.com/...ad.php?t=23790
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
      • Basstronics
        • 2384
        I have only 2 couplers available right now. One for the stock motor and one for the Tacon motor.
        Moving to .098" cable setup was a smart move for me!
        • monojeff
          • Nov 2010
          • 2728
          I sent you a PM on the tacon coupler did you ever get it??
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
          • CaptPJB
            • 276
            Moving to the .098 cable I am assuming I would I need a new coupler for the stock motor like Basstronics sells as well as this http://www.offshoreelectrics.com/pro...oct-oc098L-24c?
            Peter
            • wparsons
              • 461
              You could also contact Jeff Wohlt to get a wire drive made for it. I'm planning on making my own wire drive if I keep mine for this summer, but might be selling it to free up space for a new build.
              Light travels faster than sound, so people may appear to be bright until you hear them speak.
              • SweetAccord
                Speed Passion
                • 1322
                Use the Etti coupler one OSE which is better than any set screw coupler. This is what I'm using. If you mod it you can make it easily fit the .098 flex cable tightly and no more damaging set screws into the flexdrive and it will hold evenly not in one or two places like a set screw coupler. Steve has these here as I asked him to get these for me for all my 2040 motors and he has more left.
                • SweetAccord
                  Speed Passion
                  • 1322
                  Originally posted by monojeff View Post
                  This is what I'm using also works great. Get rid of the bushing in the strut. Search the RC Universe thread for Mini Bolt and you will find my post on the bearing mod. It's easy and works extremely well.
                  • Basstronics
                    • 2384
                    The Etti coupler fits?
                    I know there is a length and diameter limitation- not much room.
                    I had Jeff make me a .062" wire drive and a special coupler. The wire is just to big for the bend at least on my Bolt. The drive/coupler is in the FS section if anyone wants to give it a try.
                    • wparsons
                      • 461
                      Octura makes a collet for a .098 cable as well, but the motor end is 1/8" (540 car motors), you can cut a short length of brass or aluminum tubing to sleeve the motor shaft and it will work just fine. Just notch through the tubing so the set screw goes right to the motor shaft, not just the tubing.
                      • CaptPJB
                        • 276
                        Since I have been known to buy the wrong sized coupler in the past :) can you give me the product ID for the OSE coupler please? I assume that the OSE .096 flex means I need to mod the strut housing bearing as well? I will search RC Universe as you suggest for how to etc.
                        Reasonably new at boats so apologize if some of this is obvious to more seasoned FE boaters!
                        Thanks
                        Peter
                        • wparsons
                          • 461
                          If you get a 1/8" stub shaft you should be fine with the strut as it is stock. You could run a smaller diameter teflon liner with the smaller flex, but don't have to.
                          • CaptPJB
                            • 276
                            Thanks for the info no strut mods needed.. Regarding using a Octura collet and a sleeve I would prefer not to do that if an Etti will fit.
                            Peter
                            • CaptPJB
                              • 276
                              Is this the one and you enlarge the 2mm end to 2.3mm or there abouts for the .098 flex?
                              Product ID: etti-a006
                              Etti Coupler 3.175 to 2mm
                              In Stock: 8
