Radio questions for micro boats
  • sjslhill
    • 1563
    I am building a 1/24th scale boat for R/C
    What radios are out there for this. I need a very small receiver and servo. I will most likly be running at most 3 of these together in the future. Any ideas?
    thanks for your time
    Steve
  • crazzy maxx
    • Dec 2007
    • 498
    hs-55 micro steering servo
    and a mini lst radio and reciver are pretty small to.
    i have radio and reciver if u want it.
    snort pixi sticks=symptoms-:
    • SJFE
      • 4867
      Steve you may want to look @ unitedhobbies. They have a ton of micro receivers. I'm sure you can find somthing that will work:).
      • ED66677
        • 1300
        beware of micro receiver, they were originaly designed for park flyers, so the range of use is very short, don't go too far with your model or you will loose control
        Emmanuel
        • Eyekandyboats
          • 1935
          I believe there is a servo called the blue bird which is even still smaller then the HS55.
          as for receiver, will you will have to find one that works with your radio which is not always the easiest thing to do, Or you use a air plane radio and you will have a whole slew of recivers to fit the boat
          EYEKANDYGRAPHICS
          www.rclipos.com
          • sjslhill
            • 1563
            thanks guys....no airplanes where I run, it's a lake with trees everywhere.
