30-40cm carbon fibre hull
  • minigazz
    • 85
    Hi, this is my first post on this brilliant site! Basically I am looking to build a carbon fibre boat hull which is between 30 and 40 cm in length. I want the boat to be fast, reliable and stable - ie i dont want to be fishing it out of the middle of the bond with a big stick because it has turned over! I have previous experience in making boats, including a 60cm wooden catamaran, a 35cm vacuum formed HIPs mono and a modified NQD tear into - all with moderate success.
    I also have a little experience in composites, however I do not have the knowhow to make a boat hull and I am very unsure of how you would go about this (ie mould making/joins/canopy etc)
    I am very unsure of what type of hull to make too, I know the mono's are considered easier to setup, but I tried a surface drive with my mono hull and it didn't perform very stably at all.
    I was hoping to pick you guys brains on my issues here!
    Here are some links to my previous projects - enjoy!
  • Cope
    • 23
    I cant help you with your building as I have yet to try making a hull.
    As far as the little yellow mono goes, I would try to make the battery movable for CG changes. This should help keep it from leaping out of the water.
    Your builds look nice. Good job.
    EDIT- you may also want to check and see if the hull is true on the bottom. If your hull is untrue at those speeds your guaranteed chine walk. At that speed you may even want some hook (A small indention in the ride surface) in the rear. Hopefully someone who knows more than me about designing hulls will chime in and say for sure.
    • minigazz
      • 85
      Ah, thank you! It really does have issues with jumping out the water! I did try moving the battery but it then started submarining! The lipos really did bring that thing to life! I was thinking maybe a carbon fibre version with a little longer hull would act more stably? I also dont like the poor handling due to the surface drive and offset rudder.
      • Cope
        • 23
        See if you can try to get some video of it running on smooth water,It would help folks more. It's hard to tell much when running in a creek.
        Your right, Longer will be better.
        Looks like the sucker handles great to me?
        You can get or make a non off set rudder if that's what you don't like?
        Most folks off set the rudder to help with prop walk. I would think at your speed prop walk is a major issue? Are you using sharpened and well balanced props? If not that could be a large issue.
        You have a very small boat going at considerable speed, (up current even) everything needs to be just right.
        Again very nice job.
        • minigazz
          • 85
          Yea, I had kind of tossed it aside as I thought it was overpowered and underdesigned - I will get it going at some point during easter if i can and then get some footage. Am i right in thinking the chine walk is the rocking motion where the bow of the boat jumps up and down? I think I am expecting too much from a surface drive system, I would probably be better with a sub-surface system? Is prop walk where the boat moves sideways or 'strafes'? If so then this wasn't really much of an issue. cheers
          • minigazz
            • 85
            Here is my flickr page if it is of interest http://www.flickr.com/photos/6071874...7626282078644/
            • Cope
              • 23
              In my first post I edited out where i suggested getting an adjustable strut. It seems all the new boats are going surface drive. You may have good luck with going to a new stuffing tube and an adjustable strut, but I think you can just bend the out drive a little?
              Yeah prop walk is the boat tending to turn to the left under power. (For counterclockwise rotating props)
              Chine walk is side to side.
              porpoising is jumping up and down and is the thing I see in your video.
              Have you tried many other props? that one may just not be right for the boat?
              You could also just go to JAE or zipkits and get some free plans for a nice rough water mono and scale them to your size? With your building skills it should be a walk in the park?
              • minigazz
                • 85
                Thanks, i will be sure to check them sites out!
                If that is porposing then I have labeled that video wrongly :-s oops!
                I want something fast like that one, but much easier to drive! As i mentioned I have a modified NQD tear into which is quite fast, but nothing too special and a little plasticy as it is basically a kids toy with brushless power!
                Sadly that boat uses a shaft rather than a wire, so bending it isn't really a possibility!
                Thanks for your help - its the first time I have ever used a forum before, it would have made my past project much easier!
                • SweetAccord
                  Speed Passion
                  • 1302
                  If I had your skills to build a boat I would not try to re-invent the wheel. I would just get a bare hull or copy one as there are many great hull designs out there already. If you want speed a rigger are excellent in speed and handling.
                  Just my stupid opinion.
                  • Cope
                    • 23
                    Why not go to a flex shaft drive? wont last as long but will allow some fine tuning.
                    • minigazz
                      • 85
                      Yea, I like building things from scratch though! I will look into flex drive shafts - they seem very expensive here in the uk though!
                      • sundog
                        Platinum Card Member
                        • Feb 2009
                        • 878
                        Minigazz, one problem with the yellow boat is you are using an outrunner motor in a narrow hull. That's why it is corkscrewing (barrelroll). Go to an inrunner motor - a 20x40mm size and keep the speed below 3000kv. That should give you good response and speed.
                        Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
                        • minigazz
                          • 85
                          Well I ran the other day with an inrunner motor and it seemed a little more controlled if nothing else! I didnt get any footage unfortunately as my only camera is my iPhone and I didnt fancy juggling it with this thing while trying to keep it under control!
                          What I found was that it would jump out of the water very frequently, giving poor control and not allowing you to really open it up. I moved the battery as far forward as possible, but it ended up just submarining, which caused water to get in and ruin my lovely £5.50 ESC - sadface!
                          I dont understand how the flexishafts work and what parts i need to implement one into my boat. My understanding is that you have a strut on the transom which holds a solid shaft with some bearings or bushes in and the flexishaft connects to this somehow? I dont understand how the shaft tube connects to this though and how leaking is prevented at the transom.
                          Cheers!
                          • Cope
                            • 23
                            The flex fits into the stuffing tube, this fit along with grease and the direction of the winds in the flex keep water out. The flex is held to the motor with a collet or grub/set screw coupler. the end of the flex can go to another coupler that holds the threaded drive shaft or just be a welded flex where the drive shaft and flex are welded together.
                            See here. (EDIT-Scroll down )
                            http://www.offshoreelectrics.com/categories.php?cat=17
                            • minigazz
                              • 85
                              Thanks! I was looking at using a similar size motor for this hull (ebay special mystery 1000-5000kv on 3s), would this be sufficient or should i be looking bigger? also, how do these motors compare to a quality motor of similar size/weight like a hacker?
                              cheers
