The impact also pulled the can of the outrunner foward of the motor spindle.The new boat will probably use a Leopard 2860 not sure yet on kv as i think the outrunner i used probably didnt have an awfull lot more in it, Still it was a start given it was an 8 quid motor.
JAE Mini Sprint
Has anyone tried the black 3500Kv 5 turn motor from Zipp on 3s? I found a 3s 2200mah Nanotech that just fits and I'm wondering what prop to start with. The stock 30mm maybe?Namba District 16
Thanks Martin I better look for some props. Are you the admin at Mayhem?Namba District 16
No nothing to do with Mayhem, You should be ok on 3s with some of the various carbon filled props around that ive found to be very strong. I think the stock props are ok on 2s but they are very thin & not very stiff or strong. Martin.
What do you use for timing on these motors? The Zipp esc defaults to 15 deg.Namba District 16
I finally got to run my Sprint on 3s after the race in Edmonton. I hit the throttle a little hard on the first launch and it jumped out of the water and did a backflip :) it also snapped the flex inside the stubshaft.
So after a quick solder job and a little softer launch it ran great on the stock 30mm prop.
Namba District 16
Busted :)Originally posted by detox View PostThe song in that video brings back memories. Year 1971 Ozzy Ozbourne is singing Black Sabbath's Sweet Leaf
I first heard Paranoid in 1970 and was hooked.Namba District 16
