Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 17" Hydro Looking for recommendations - RcBoaters Forum
  • monojeff
    • Nov 2010
    • 2728
    I am getting this hull from hydrojerry & will need to get all new hardware & motor for it.
    It's a 17" ABS hull
    Need recommendations on running 2s higher Kv or 3s Lower Kv motors.
    I'd like to keep the costs down on this as it is just something to play with.
    Figured I could run hobbywing 35amp esc
    Motor TBD possibly 4800kv
    Strut Micro
    Rudder Micro
    Or was thinking maybe a 21 size rudder might be better? A little more length??
    Mini Servo
    Props TBD on motor choice
    Tips Advice greatly appreciated!!
    This is my first electric build other then my 1/10 scale thunderboat which I am in the process of scratch building.
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
  • monojeff
    • Nov 2010
    • 2728
    No on with any input on this boat?
    Thoughts on the setup I posted??
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • madgadget
      • Oct 2010
      • 200
      I've had good luck with the hk motors in 450 size heli's and just ordered 3 more to play with in my mini hydros.
      http://hobbyking.com/hobbyking/store...idProduct=6261
      http://hobbyking.com/hobbyking/store...idProduct=6387
      This esc has worked for me and I proved it was waterproof as well.
      I have one in my 17.5 hydro and ordered 3 more. Someone more experienced than me will have to help you with running hardware. I make my own or make guessestimates. Go big and trim it down till it works. Best of luck to ya
      Gas Segad / Gas Rigger / Radtek carbon cat / micro fe rigger / fe ***** in work
      • ENCORE MAN
        • Jan 2010
        • 1096
        I have some Minicat hydro parts, strut ,rudder, flex shaft etc, I will dig them out and get back to you. If you use these parts, you can always get spares from Sailr.
        • monojeff
          • Nov 2010
          • 2728
          Appreciate it keep me posted!
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
          • monojeff
            • Nov 2010
            • 2728
            I think I am going to go with a 12 size rudder just for a little more length.
            http://www.offshoreelectrics.com/pro...prod=ose-80051
            Most likely will need a new standoff to bring it closer to the transom.
            OSE GIFTING ELF
            HAPPY HOLIDAYS!!
            • monojeff
              • Nov 2010
              • 2728
              I am also debating going with this motor option instead.
              3000kv motor http://www.hobbypartz.com/88e-ads-30...ool-motor.html
              OSE GIFTING ELF
              HAPPY HOLIDAYS!!
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1743
                I used to run a 17" hydro with a Feigao 380 8l on 3s.
                • monojeff
                  • Nov 2010
                  • 2728
                  [QUOTE=BakedMopar;295890]I used to run a 17" hydro with a Feigao 380 8l on 3s.
                  /QUOTE]
                  I have seen this video boat seemed to run very well!
                  I am thinking the 3000kv motor should give me a little more to work with.
                  Also reading that the 4800 motor shaft tends to bend easily.
                  I am trying to keep my costs down as much as possible on this build so every little bit counts.
                  OSE GIFTING ELF
                  HAPPY HOLIDAYS!!
                  • monojeff
                    • Nov 2010
                    • 2728
                    Thinking one of these motors will be a good choice possibly instead of the others
                    3500kv outrunner
                    http://www.hobbyking.com/hobbyking/s...dProduct=11178
                    4400kv outrunner
                    http://www.hobbyking.com/hobbyking/s...dProduct=11177
                    I would obviously need to jump the esc up to the 60amp
                    ot I could even go up to the 90amp esc
                    Thoughts??
                    OSE GIFTING ELF
                    HAPPY HOLIDAYS!!
                    • monojeff
                      • Nov 2010
                      • 2728
                      Do you have any videos on this setup?
                      What boats are you running & what are your temps like?
                      OSE GIFTING ELF
                      HAPPY HOLIDAYS!!
                      • monojeff
                        • Nov 2010
                        • 2728
                        Striped the paint off & started sanding & filling the hull for it's new paint job.
                        Lots more work till I get it smoothed out!!
                        OSE GIFTING ELF
                        HAPPY HOLIDAYS!!
                        • HYDROJERRY
                          • Jan 2010
                          • 2709
                          Many layers of paint there huuu,, the first coat cracked and i didnt no what to do so i tryed everything i could think of,,sorry for the extra work bro...
                          • monojeff
                            • Nov 2010
                            • 2728
                            NO WORRIES you HOOKED ME UP!!!!
                            Nothing a like a little elbow grease.
                            I'll get it all smoothed out.
                            I could have taken it down further but figured the primer seemed to stick pretty good so just smooth it out from there.
                            I'm not sure if I will strip the bottom paint or not, was thinking I will just light sand and give it a coat or two.
                            OSE GIFTING ELF
                            HAPPY HOLIDAYS!!
                            • RandyatBBY
                              • 3943
                              Randy
                              BBY Racing
