Need boat !
  • badag98
    • 206
    #31
    I have an echo and love it, the fact that it turns on a dime at full speed is hard to beat!!!
    • EhDolph
      • 21
      #32
      Do you run yours on 2cell or 3cell Lipo ? Was your MiniEco self righting out of the box or did you have to tweak it ? If so what did you have to do ?
      • Diegoboy
        • Mar 2007
        • 7443
        #33
        I ran mine on 3S, yes it self rights out of the box (it has a flood chamber). Stock vs. Stock, I'd say the eco is faster.
        Nothing turns like an eco!
        • EhDolph
          • 21
          #34
          Will changing the prop or batterys have an effect on top speed or is the stock configeration pretty much as good as it gets for speed with out changing motor ?
          • Diegoboy
            • Mar 2007
            • 7443
            #35
            You can change the motor, but it's stock motor is all that this hull needs on 3s. If you run 2S, you can change the motor to get more speed.
            • badag98
              • 206
              #36
              I run my echo on 3s, and had to add a couple extra holes too the flood chamber plus some lead weights on that side as well.
              As for upgrades, I'm not sure you could use a much bigger prop due to clearance issues. The stock motor is fast on lipos
              • sailr
                • 7128
                #37
                watch the videos. They are totally different in how they drive. The esc's are irrelevant as they work with the motors installed. The carbon props work great on the mono. The reason for the stainless prop on the ECO is because it is tiny. Carbon would never hold up in such a small size.
                Mini Cat Racing USA
                www.minicatracingusa.com
                • badag98
                  • 206
                  #38
                  Well if your not going to buy my micro cat I have listed.....lol
                  My vote would be the Mini Echo, its a pond rocket that makes 90 degree turns. Of the boats I have it is by far my favorite. It is fast and turns on a dime plus you will not have to go swimming like I have after my SV!!
                  Good Luck
                  • martin
                    • 2881
                    #39
                    As Sailr has said their very different types of boats, The Velocity is a surface drive deep v that rides very well in chop ( relative to its size ) & i would say is probably faster in a straight line. The Mini Eco is a mono that is still used at world championship level & is sub surface drive & will turn much faster ( blink & youll miss it ) but needs less chop than the Velocity. Very difficult to pick one over the other. Thanks Martin
                    • SweetAccord
                      Speed Passion
                      • 1322
                      #40
                      So you are not considering the Starship anymore? It's the fastest of the bunch.
                      • martin
                        • 2881
                        #41
                        SweetAccord for my own interest how stable do you find the Tenshock minicat & do shafts last ok in them, Also considering the Hor Bolt Micro but dont know much about them though. Thanks Martin.
                        • SweetAccord
                          Speed Passion
                          • 1322
                          #42
                          I have not replaced the shafts and they last a long time being a wire. I do run the liner in mine and oil it after every two runs. The Minicats are stable no real issues, or quality issues. I'm still waiting on my Bolt to say how I will like. It's a copy of the Minicat Hydro but the drive line it larger and the motor coupling is larger. Overall there is not a HUGE difference. Just minor ones but I have not done a 1:1 comparison yet. I do prefer the looks of the Minicat.
                          • SweetAccord
                            Speed Passion
                            • 1322
                            #43
                            Martin, get with these guys on the Hor as they have run them. http://forums.offshoreelectrics.com/...ad.php?t=21402 You can see how the Bolt runs on youtube. Hobby King carries it also and I believe there is a review of it on youtube also.
                            Hope that helps.
                            • martin
                              • 2881
                              #44
                              Is the wire drive you have in the Minicat an after market one that you fitted as i thought they came with flex shafts as standard, Or am i mistaken. Thanks Martin.
                              • SweetAccord
                                Speed Passion
                                • 1322
                                #45
                                You are correct. It's the flexdrive that is how it comes and I am using the original one. I call them the a wire drive and that is my bad. To me they are both a "wire" but that is incorrect thinking.
