15" Small Bolt micro hydro
  • Basstronics
    • 2384
    I am going to be reworking my 15" Small Bolt micro hydro.
    It is one from Hobby King. I have upgraded the ESC to a 30A Etti and a traxxas servo.
    Anyone else have one?
  • SweetAccord
    Speed Passion
    • Oct 2007
    • 1322
    I have another one on the way. The first one was damaged via postal and I get to keep it so extra parts, and another one is being sent. I'll probably swap the motor out for a 3900Kv and use a 30A Seaking ESC.
    • Basstronics
      • 2384
      I see you edited your post. I started the Small Bolt thread on RC universe. I find myself calling this board home over the others.
      So I decided on a theme for the boat. Now I need someone who can make me decals! I also picked up the paint.
      Can anyone guess the color? lolz
      This is my first boat/decal graphics design. Is there anything else I should add? Im a fun run person, no racing.
      I got some putty to sand and then to the paint booth- AKA the basement... Hopefully I can get the paint done over the weekend. Two coats of Rustoleum and no clear (for now).
      • CHUD
        • 554
        hay bud
        Nice micro hull bass! If you need someone to do the decals try monojeff he did a nice job with my mini befu cat hull,and hydrojerry's
        • Basstronics
          • 2384
          I got a PM into him with no response as of yet.
          • wparsons
            • 461
            I've got one, stock except for an x632 prop and some block sanding to the sponson bottoms. I also cut a bit off the stuffing tube so I could get a bit more negative angle on the strut. I've also reinforced the transom with some 1/32" ply after hitting a stick and breaking it apart a bit.
            I've been thinking of repainting it, but I think I'll just leave it as is for now.
            Light travels faster than sound, so people may appear to be bright until you hear them speak.
            • SweetAccord
              Speed Passion
              • Oct 2007
              • 1322
              LOL! I removed my post after I realize you are the same Basstronics on there as you are on OSE. I'll give more input on this hydro when I get it and how it compares to the Minicat hydro.
              • igottalongone
                • 204
                • CaptPJB
                  • May 2010
                  • 276
                  One piece flex shaft question
                  Was considering upgrading my Small Bolt shaft to a one piece setup. Can anyone point me towards what is needed? I would prefer to support Steve and OSE if possible.
                  Thanks
                  Peter
                  • wparsons
                    • 461
                    I'm looking into options for the same. Right now I'm considering getting a coupler/flex/stub from a mini rio, unsoldering the flex and soldering in music wire and running that. I'm sure there's similar parts available, but I noticed it while upgrading a friends mini rio to a wire drive a few months ago.
                    • Basstronics
                      • 2384
                      I just ordered up this option.
                      http://www.offshoreelectrics.com/pro...oct-oc098L-24c
                      Then you need a coupler- the fun part. There is one left in the swap shop- I bought the other.
                      http://forums.offshoreelectrics.com/...ad.php?t=21159
                      I decided to change up my theme on this. No more pink panther... Paint still happening this weekend. Gotta get this ready for the water!
                      • CaptPJB
                        • May 2010
                        • 276
                        Starting CG for Small Bolt?
                        Come someone please give a starting point for the CG for a Small Bolt? Some folk seem to prefer a sideways battery just ahead of the motor citing better CG adjustment range others put it in line down the center.
                        Mono's are 25-30% from transom but not sure about a hydro as they basically run on the two front pads and the prop.
                        Thanks for any help or comments
                        Peter
                        • martin
                          • 2881
                          Tenshocks Minicat hydro is very simular hull to the Bolt in size & they use 6.1" in from the transom for the cog point, This should give a starting point & then go from their either way if nessesary. Thanks Martin.
                          • wparsons
                            • 461
                            I run my battery (3s 2200mah) lengthwise as far forward as I can without it interfering with the hatch.
                            • CaptPJB
                              • May 2010
                              • 276
                              Two Part Shaft Tips?
                              OK I have to ask, is there an easy way to get the shaft out to grease etc. I removed the strut pulled off the drive end but had a heck of a time getting the flex shaft out. There is nothing to catch hold of as it is inside the copper tube, finally sort of pushed with a screwdriver on the flex shaft by the coupler until I could get some pliers to grip the other end.
