little rigger???
  • steve-b
    • Mar 2010
    • 245
    little rigger???
    Hey all,
    I just bought a small rigger (18"). I will be running a Lehner 1530/8 3572kv, and a 120A ESC, 3s batteries.
    I'm thinking that ill use a .130 flex as i can get a 4mm/.130 coupler from OSE.
    My question is... what size prop would be a good place to start? Ive never had a rigger this small before, and I'm not sure.
    This boat will be intended for SPEED and that's it.
    Any suggestions on a set up would be great, even what hardware to use, as ill need that too.
    Looking forward to reading your thoughts... i know theirs allot of knowledge on this sight.
    SHOW ME THE LIGHT.
    Steve.
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    2S lipo
    This Rudder
    3/16 Small Strut & 2 1/4 Inch Rudder w/ water pickup on THIS page
    THIS flex shaft
    and...
    THIS prop
    • steve-b
      • Mar 2010
      • 245
      YA, i ment 2s.
      Thanks for the info.
      • NativePaul
        Greased Weasel
        • 2764
        2s on 3572KV with an X432 will be slower than a mini oval boat which run around 30 mph but should net you about 7 minutes run time on 2200mAh pack, 3s on that same prop should be a little faster than mini oval, we have guys that use that same motor on 3s with a 29mm prop for mini oval's 5minute run time, an x432 should net you about 3.5minutes on 3s 1800mAh, for SAWs I would go 3s and an x632 with the aim of moving up to a v935 if everything is cool.
        • steve-b
          • Mar 2010
          • 245
          Well, i certainly want to go allot faster then 30 mph.
          • Alexgar
            • Aug 2009
            • 3522
            id start with plastic props before i went all out an a s/b prop
