Motor for a 12"-14" Cat (single)
  • Simon.O.
    • 1521
    As you can see I am surfing for input for motors for 2 cats as I plan on building both at the same time.
    This is for the smaller cat and I have ruled out an outrunner as a single and am now looking at these inrunners.
    Which is the better choice and why.
    http://www.hobbycity.com/hobbycity/s...ess_Motor_(FIN)
    Both can provide me with the power (W) that I need, the esc and packs is the easy bit, I will provide the motor with plenty of energy.
    I am looking to run M4 graupner K series small props on 3S.
  • CornelP
    • 745
    The 2835 will give you way more torque than the small 2040... plus the small one is KD, so maybe not so good quality as the Turnigy.
    • Jesse J
      scale FE enthusiast
      • 7241
      I need to learn lots more about small motors, I'm watching!!
      "Look good doin' it"
      See the fleet
      • ozzie-crawl
        • Sep 2008
        • 2865
        hey simon how about a little out runner
        • Jesse J
          scale FE enthusiast
          • 7241
          dunno, but you might need at least two of em ...
          See the fleet
          • Alexgar
            • Aug 2009
            • 3522
            i run a 28-47 2700kv in a 16" vee on 3s and 4s with great results a little pricey but bought before i knew about hobbycity
            link
            • Simon.O.
              • 1521
              Interesting replies so far. Notes taken.
              Here is another option, the reviews below it indicate that a 300mm or less prop will be fine.
              http://www.hobbycity.com/hobbycity/s...r_(WaterCooled)
              I realise that it is 20mm dia and may lack a bit of torque.
              • NativePaul
                Greased Weasel
                • 2764
                I would go for the third one, I know somweone who ran the second one in a cat of about that size but there not the most efficient and it got hotter than I like to see even on short runs, it definatley needed water cooling, the first motor is just too big/heavy for a hull that size, more suited to your 18incher, over here we use speed400 size motors like that in our mini classes which are max 450mm (18") hull length and its the 5minute runtime we need, not the motor size that keeps the boats sensable, propped up for a few striaght line runs as I believe you run and there is plenty of power there to make a mockery of an 18" hull in all but the most glassy of conditions.
                PS, Definately keep the prop under 300mm, I have a rule of thumb that says "when the prop diameter approaches the hull length, the chances of an adverse torque reaction increase considerably"
                • Alexgar
                  • Aug 2009
                  • 3522
                  16" vee 3s 28-47 2700kv 40 amp esc, not to shabby
                  • BakedMopar
                    No Mo Slipah
                    • Sep 2009
                    • 1679
                    What about these
                    http://www3.towerhobbies.com/cgi-bin...?&I=LXLWW5&P=7
                    http://www3.towerhobbies.com/cgi-bin...?&I=LXLWW4&P=7
                    You can get water Jackets here
                    http://cgi.ebay.com/aluminum-water-c...item439aa338fc
                    A 380 can IMO is too big and should be in hulls 16" or bigger.
                    • Simon.O.
                      • 1521
                      I am now leaning towards it myself
                      Cornel mentioned that it is a dubious motor
                      the first motor is just too big/heavy for a hull that size, more suited to your 18incher, Could do
                      Propped up or celled up ? do I go 2S and go up a prop or go 3s and down on the prop.
                      Love a typo !! you know I meant 30mm
                      Originally posted by BakedMopar View Post
                      What about these
                      Nice links an I'll keep them but for now the big issue is shipping, by the time i land them the post is more than the item.
                      George, do you think the 20mm motor may be the go too?
                      • ozzie-crawl
                        • Sep 2008
                        • 2865
                        i still think the scorpion 22mm are better motors, yes they are more $$$ but rebuild able
                        and can take some very high temps. and this is a Aus $$$ not u.s
                        http://www.arkinnovations.com/shop/i...ex&cPath=16_46
                        • Simon.O.
                          • 1521
                          Nice motors there Scott, but this will deffo be a Inrunner job. It will be small and narrow so an OR will flip it too easily.
                          I may yet go OR in the bigger 18"(wet)20"Loa cat.
                          Looking and looking for now.
                          • ozzie-crawl
                            • Sep 2008
                            • 2865
                            hopfully there in runners will be out very soon
                            up to 40mm are 4 pole over 40 mm are 8 pole .had a email from them about 6 weeks ago and they said 2-3 months
                            • Rumdog
                              • 6453
                              The ammo motors are excellnt! http://cgi.ebay.com/Great-Planes-Amm...item562e963947 Check out the other sizes and winds they have as well.
