When charging lipo cells, is it absolutely necessary to balance them? The reason why is because im planning to wire my two 2S packs in parallel. I only have one 2S balancing port (and adaptor) on (and for) my charger. This means i can only have one pack balanced at a time when charging. I could charge them one at a time, but that means i would have to make a parallel harness for them, and i dont have enough plugs to do that (using bullet plugs, not deans). Could i still hardwire both packs in parallel? and only balance one pack while charging? (i would balance the other one on the next charge, and so on)
im not too good with words, so here a pic to help explain it a little better.
the one on the left is what i was planning to do, but if both packs NEED to be balanced while charging, then i would have to make a harness like the one on the right so i can seperate them....the only problem is i dont have enough plugs to do this....i can buy more, but only if its absolutely necessary.
what should i do?
what should i do?
