What do you guys use to secure your props? Up til now i have been using a standard non lock nut along with the bullet nut, and last run the boat flipped on me doing around 25mph in a turn. Dont know if it was the flipp that coused the prop to come loose or if it was the other way around.
I usualy thighten the inner nut with a socket along with an extender and tighten it with my hands untill its quite tight, then i use the slighly more pressure on the bullet nut.
The reason why i dont use a lock nut is becouse the drive shaft is not long enough to use the bullet nut aswell.
Should i trow away the bullet and just stick with a lock nut or do you have any other tips?
Thx
Thx
