HELP.. water pic up esc cooling in ECO MANTA
  • SweetZ28
    • 1535
    Hi guy's I ran my manta for the first time today..as seen in the video section... Anyhow my esc as seen in the photo was 165 Deg and the motor was under 100Deg thing is when i was running the manta i could not see any water exiting the rear water port ? So i took it home and drilled the hole in the bottom pick up out a little bit biger and also added a thin section of lexan with a slight turned up front...see photo bottom of boat...do you think this will work out well and make more water flow?
    It seems hard to blow air through the whole system as you can see how long the tubing runs and also i have a motor coil with the brushes water cooled also...if feels hard now to blow the air through BUT i need to run maybe 2 more little pipe sections glued down on the esc to cool it.... I am afraid this won't work it will add even more pressure.... Or will my mod on the inlet help out?
    Any info or help will be GREAT..
    WWW.PPRSLOTS.COM
