Which bullet connectors are the best?
  • Anbjorn
    • Apr 2009
    • 255
    Witch of the connectors below would you recommend to use to connect Hyperion G3 VX Lipos to a Schulze 40.300 esc? (300/400A)
    http://www.offshoreelectrics.com/pro...=ose-8mmbullet
    http://www.offshoreelectrics.com/pro...s-65-connector
    Would you say that one is better than the other? From the limited spec and description it is hard to choose.
    Reliability, capacity and quality is the only criterias.
    Thanks
    Anbjørn
  • jcald2000
    • 786
    Here is what I use, 8 gauge fit easily.
    • Anbjorn
      • Apr 2009
      • 255
      Great link.
      Thanks
      Anbjørn
      • Himalaya
        • Apr 2009
        • 259
        The Castle 6.5mm bullets are awesome, very tight when plugged, very low heat when running, but the tightness also make it less suitable for places where frequent plug/unplug is required like battery connection. From what I've been using, a Deans or TRX would be sufficient for any app under 100A, much easier operation plus no chance of reverse polarity, which you know is extremely destroying.
        for higher amps just run two or more packs in parallel.
        • Anbjorn
          • Apr 2009
          • 255
          Yeah I ordered some of the Castle ones too, but I will probably use the 8mm OSE bullets. Ordered 20pcs of them for connecting the 4 Hyperion VX 6S 5500mAh to the esc. Going to run 12S.
          I will probably also need to make a safety loop on each side of the boat.
          Not too much space available when putting the 3080 in.
          Anbjørn
          • kevinlew211
            • 706
            Anbjørn
            Anbjorn,
            All i can say is WOWWW
