32" Mono Rec's.
  • saleens7
    • 1130
    double post
    saleens7, the wookie of rc boating
    • saleens7
      • 1130
      • FE_Chris
        • 906
        I know this, in a previous post I said I have 35-MM to 55MM props and I have some mid-sized bronze ones too.......
        So back to my original question....What XL motor should I be looking for using direct FLEX drive in a 32" mono on 16-20 cells. I'm not after run time...I'm after speed.
        Thanks!!!!
        Fast Electric and Fast Ford's / V8 Mustang Enthusiast
        • hammertime
          • 517
          in a 32" hull i would go no lower than a 10xl
          60% of the time... it works every time!
          • FE_Chris
            • 906
            Can I ask why? Someone else said a 9xl would do me fine....Thanks.
            • steveo
              • 1595
              i have the same boat and i have read threads that the boat does not like to go over 40 mph i dont know why its just what i read
              how fast is the boat with the 16 cell gear drive?
              i think you would be good with a 12 xl on 16 cells, lower amp draw easier on your components and you can always prop up, for direct drive
              i will be following this thread to see what you do, i'm looking to re power my boat as well
              • RMZDADDY
                • 395
                If you're really looking to use 16 cells and up in a 32" mono, a 10xl would do it IMO. With 16 cells that would be about 32k no load rpm at the prop. I'm running a 12xl,24 cells, 1.33:1 gears to get about 31k at the prop. This is in a 32" mono (Toysport Triton). With an M645 prop top speed has been 51.1mph. You may not need that large a prop to achieve the speed you're looking for, your setup would be lighter with only 16 cells. Hope all this helps!
                • FE_Chris
                  • 906
                  Hmmmmmmmmmmmmmmmm 12XL.................or 10XL..............Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmmmmmmmmmmmmmmmmmmmm
                  Thanks guys. yeah, I wanna run 16 cells. AND I wanna run 20 cells.
                  • adreher
                    • 74
                    Hey guys, sorry to butt in but I have am having some of the same questions. I have a 29" titan and am going to be running any where from 14 to 18 cells on a flex drive. So kind of looking for the same answers as far as what motor would be good for that set up? Thanks guys.
                    • Doug Smock
                      • 5359
                      Then you also want to run at least a .150 cable. Right??
                      Doug:)
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • FE_Chris
                        • 906
                        I dunno doug, what do you think?.....it's setup for .130.............
                        • ReddyWatts
                          • 1756
                          12XL, 20 cells, X640 prop, 75 amps, .150 cable, 40 mph
                          ReddyWatts fleet photo
                          • Doug Smock
                            • 5359
                            Yes sir, better safe than sorry.
                            You'll be asking alot of the .130.
                            It won't take much to change it over and you'll be glad you did.
                            Doug
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • FE_Chris
                              • 906
                              Ehhhhhhhhhhh sounds like a bunch of work....The tube is epoxy'ed in... I'd have to get a tube bender............Ehhhhhhhhhhhhhhhhhhhh
                              • ReddyWatts
                                • 1756
                                You might be able to pull the nylon stuffing tube out of it and just run the .150 cable directly in the tube. You willl need to clean it and keep it full of grease after each day of running. This is what I have been doing. Anyone else tried this?
