power source for triton jr. Can't beat $12.79
  • yurkanip
    • 495
    I found this power source. A switching 12v, 7 amp power source for lcd monitors. Cut off the plug, found positive and negative with my volt meter then soldered to the leads my charger, heat shrink...works like a charm. No reason to buy a $50-90 power source. Unless you are charging multiple 4s packs etc with big chargers.
    Just wanted to share it with you all. The Watt output is far above what I draw when charging single 2-4s packs. I believe and it will work for any charger of 1-4s
    There are multiple amp output power sources that can be obtained from the same seller...for high output chargers at various cheap prices. here is the link.
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=230346900474
    Cheers.
