counter-rotating props ?
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    Just for fun, I re-powered my scale Coast Guard boat with some Titan brushed motors I had left over from the Twinstorm days. The stock wimpy motors turned some wimpy props [ picture]. I want to re-prop and I'd like to know if there's any advantage to install counter-rotating props, and if so, to rotate inward or outward ? The boat has a forward & reverse SC if that matters to the setup. There's a nice selection of eligible props right here, so any input would be well received !
  • Jesse J
    scale FE enthusiast
    • 7818
    Bonewar reports that cats turn better with props that rotate inward (clockwise on the left). I have found this to be true but have not tested other combinations. You may not have pronounced problems without a huge thrust cone like Bonewar and the twin cat brigade.
    "Look good doin' it"
    See the fleet
    • Diegoboy
      • Mar 2007
      • 7443
      The general rule in scale boating is:
      Inward (as Jesse describes) for speed
      Outward for stability
      • properchopper
        • 7708
        Thanks for the info. Will go with inward. Since the hull is a semi-displacement design & won't be going that fast it may not make a whole lot of diff, but I'll give inward a try.
        • Diegoboy
          • Mar 2007
          • 7443
          Inward will lift the stern...
          • properchopper
            • 7708
            Good stuff. Actually the boat's heavily ballasted to keep it from "bobbing" , it pretty much just plows through the water in a "semi-planing" attitude. Looks pretty cool underway; It's a scale model of the 47' Textron Coast Guard rescue/patrol craft & definitly excites my "scale" fascination
            • Diegoboy
              • Mar 2007
              • 7443
              I got SJFE into Scale boating!
              My plan is slowly coming to light!!!
              • 785boats
                Wet Track Racing
                • 3423
                This may help you decide.
                Cheers.
                Paul.
                • ED66677
                  • 1300
                  counter rotating props, inward or outward, make a difference on surface piercing props but on fully submerged? not sure if there's any interrest?
                  Emmanuel
                  • egneg
                    • 4759
                    You don't know it yet but I am getting this delivered tomorrow. My winter project!
                    IMPBA 20481S D-12
                    • Diegoboy
                      • Mar 2007
                      • 7443
                      I thought he already made a choice?
                      • Diegoboy
                        • Mar 2007
                        • 7443
                        Are you going to cut it off the stand and put a motor in it?
                        • egneg
                          • 4759
                          That's a stand! ... I thought it was some kind of hydrofoil?
                          IMPBA 20481S D-12
                          • Jesse J
                            scale FE enthusiast
                            • 7818
                            Where's the project if it is already built??
                            See the fleet
                            • egneg
                              • 4759
                              It isn't built - it comes as a kit from Dumas.
                              IMPBA 20481S D-12
