New to brushless..help
  • boater76
    • 574
    I was thinking of going brushless for my next build but I know nothing bout it. Can anyone help me out? Thanks.
    Ken
  • sailr
    • 7128
    Ask some questions and we will try to help you. Kinda hard to start from a blank page.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • Rex R
      • 1007
      you should build the boat first, then fit the motor to the boat. generally speaking you would be advised to keep the boat under 34" if you wish to keep the costs down (somewhat ).
      rex
      • sailr
        • 7128
        I would suggest the first thing is to tell us what your budget is for your project!
        Mini Cat Racing USA
        • Steven Vaccaro
          Administrator
          • 8932
          Ken
          Spend as much time as you can reading the forum, than ask all the questions you will have.
          Steven Vaccaro
          • bustitup
            • 3072
            Ken
            my sugestion is to by a nice rtr like supervee or ul-1 and learn that basic system first...then either move on or upgrade
            • boater76
              • 574
              For starters. What do the numbers mean after the motor size. I know the s is short l is long.
              • boater76
                • 574
                And kv and any other number and letters associated with the motors.
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  My suggestion would be to make a spreadsheet to get to know what the numbers mean and what they MEAN to you as boater maker go faster.
                  start with feigaos, not only financially but conceptually.
                  the can diameter size is set aside e.g., 540 or 580.
                  then the number is similar but don't know how related to the number of turns,
                  while yes the letters are the can length.
                  All makers have slightly different KV ratings and power (watts)
                  I have made myself one of these spreadsheets and keep it handy, cause it is hard to memorize all these numbers. In your spread sheet, include MAX volts and then for really cool part: make a couple columns that allow you to multiply volts by KV to get nominal rpms. I made mine from 2S to 6S and color coded anything over 40K rpms red and under 30K blue, 30-40k being what I understand to be the highest efficiency zone.
                  A question to others, are these some kind of AC motors, versus DC? how exactly do they work? and what are the poles all about?
                  "Look good doin' it"
                  See the fleet
                  • Flying Scotsman
                    Fast Electric Adict!
                    • 5195
                    The designation KV refers to the volts to rpm formula. the short or long refers to the length of the motor. Short motors have a very high KV and are suitable for small hulls..19" the L motors are suited to 25".. XL up to 30" and I am being conservative without knowing what hull design, power, run time, prop you desire?
                    Jesse, now you know I am a slow typist. Looking forward to meeting with you in Vancouver
                    Douggie
                    • sailr
                      • 7128
                      unfortunately different manufacturers use different motor numbering systems. For example, I have no idea by looking at a number on a NEU motor what the specs are. But I know I can go to a chart on OSE for the NEU motors and get the info. The simplest ones are something like 3574 which would be 35mm diameter and 74mm length. KV is the RPM per volt and is a 4 digit number like 2200 or 3600 or 1800, etc.. The KV determines which batteries and even props you can successfully use with the motor and gives you an idea which type of boat that motor would work best in.
                      There are a couple of spreadsheets somewhere here on OSE that list all of the motors and their specs. I'll see if I can find it and post a link here. Very helpful.
                      Mini Cat Racing USA
                      • sailr
                        • 7128
                        This thread has a lot of good info: http://forums.offshoreelectrics.com/...read.php?t=271
                        And this one on RC Universe: http://www.rcuniverse.com/forum/m_7603257/tm.htm
                        Mini Cat Racing USA
                        • boater76
                          • 574
                          Thanks for the info so far!
                          Ken
