Feigao 12L or 13L or ? UL-1
  • v-spec
    • Jun 2009
    • 940
    I got a new ETTI 90 Amp speedo for my Aquacraft UL-1 and also want to upgrade the motor. I was thinking Feigao 12L or 13L or maybe something else altogether? Right now I'm running the BJ26 motor in it with a Grim 38x55 prop.
    I don't want or need a missile for a boat but I would like to run around 45mph or so and not make my electronics work too hard. It can't be too much faster than my buddies stock UL-1 with prop swap or he will get discouraged.
    What do you guys think? I'm open to suggestions other than stock UL-1 gear. Thanks!
  • Steven Vaccaro
    Administrator
    • 8724
    You will be limited by your 90amp esc. Until you get a larger esc I would stick with the stock 2030 motor.
    Steven Vaccaro
    • v-spec
      • Jun 2009
      • 940
      I don't have a stock UL-1 motor, I bought the hull only since all their electronics burn up. What's a good alternative because my BJ motor is slower than stock by a long shot. Thanks!
      • Rumdog
        • 6453
        I would then buy a ul-1 motor. It would be a very reliable setup capable of over 45mph with the right prop.
        • Flying Scotsman
          Fast Electric Adict!
          • 5190
          A great reply...what batteries are you using?
          Douggie
          • v-spec
            • Jun 2009
            • 940
            Douggie
            Enerland 4950 2 cell 25c x2 Rhino 4900 x2 and Fullymax 22c 4500's
            • v-spec
              • Jun 2009
              • 940
              I've decided (for now at least) to stick with my BJ motor and 90 Amp ETTI and spend the money I was going to use on the motor/water jacket/collet to buy more lipo's and props. I am using 38x55 on it right now but I've got an x440 x442 and x642 I could try and maybe pick up some speed.
              Thanks!
