Newbee needing help...
  • lomdel
    • 722
    11XL on 6S is pushing the limits just that little bit too far. I run a 13XL on 6S with a X442 in my 31" cat and temps seem fine and I clocked 40-45mph (once). You'll have to run a small prop with the 11XL...
    • Flying Scotsman
      Fast Electric Adict!
      • 5195
      Originally posted by Insanety View Post
      Oki, I now think know have an Idea for a setup
      For my 33" cat I'm thinking an 11xl on 6s (3x 2s 5000mAh 30c)
      As for a prop I run the numbers to FEcal, an it suggested a octura M435/3 or grimracer 36x55.
      According to FEcalc the amp pull is around 50amps +-.
      Am I going of the deep end here boys??
      I would suggest a 13 XL with that power or a
      580 10L 1,326 RPM on 6S you will be able to use a larger prop with that motor
      The esc will have to be high voltage (rated from 5 to 12S) and I would suggest 120 amp as a minimum dependant on motor and prop. Check the forums for a suitable boat esc.
      Douggie
      • Insanety
        • Jun 2009
        • 15
        oki,
        shoping list:
        540 13xl
        120+amp HV
        Seem that can't use the stuff I already have on this boat,
        I'd better stop being a cheep, and fork up... hehe
        Does anybody know when a 80a HV ESC can be usefull.
        Thank you all for helping me, hopefully I can one day return the favor.
        • Flying Scotsman
          • 5195
          If you are buying a new motor look at the 580 series for that hull length if you are on a budget. If not NEU
          Douggie
