grease and my triton
  • andym
    More Go Than Show Prop Co
    • 2454
    Just about finished my toysport triton build. 9xl is in, have my 5000mah 5s lipo, esc in, reciever in, x642 sharpened and polished. Great went to grease strut which has grease nipple and the nipple is to small for my standard grease gun. It goes every where except in the strut. Is there ends for my grease gun that will fit ? or will the grim racer grease applicator fit?
  • Steven Vaccaro
    Administrator
    • 8932
    Which nipple are you referring to? The one on the toysport strut? If so, attach a 4-5" long piece of tubing to it. Before a run, file it with a oil. It will get used during the run.
    Steven Vaccaro
    • andym
      • 2454
      Thanks Steve thats avery good idea. Any reconmendation on oil. Also you said that the fex in the triton is different and should use original. Is it possible to use any .187 flexi and shaft or are the toysport prop shafts whats an odd size ?
      • Steven Vaccaro
        Administrator
        • 8932
        I have some flex cables coming in for them. They are a bit different than the rest out there.
        I use any light weight oil. It may sound funny but I use the Corrosion X. I stated using it one time when I ran out of the regular stuff and never went back.
        Steven Vaccaro
        • Doug Smock
          • 5359
          Steven,
          Have you ever used Corrosion X HD???
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Steven Vaccaro
            Administrator
            • 8932
            No Doug. Is it much better?
            Steven Vaccaro
            • Doug Smock
              • 5359
              It seems like the same product with a greater viscosity. I have never used it on a drive, never entered my mind. I'll try out this weekend.
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
