Remote going in reverse help !!!!!
  • jacobo.jajati
    • 22
    IM GOING KRAZY WITH MY REMOTE!!!!!!
    I had a boat running perfect. I have been fidiling with another boat as all can see on other thread and took the ESC out of the original boat to test the other.
    Now that i have placed all the equipment back into the original boat i have the control only runing in reverse.
    WHAT DID I DO WRONG. i have checked the crystal, i have checked the reversing on the remote. and it will only run when i do reverse throttle
    HELPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP
    JJG
  • domwilson
    • 4412
    If this is a brushless motor, switch any two of the three wires that go from the ESC to the motor.
    Government Moto:
    • Ub Hauled
      • 3051
      switch any two wires position on the motor side, for instance:
      if the wires were 1, 2, 3
      go for,
      1, 3, 2
      That will reverse the directions of the motor, if the steering servo is reversed just switch it on the remote control.
        ... and it will only run when i do reverse throttle...
        Now I'm confused. It will not run when you squeeze the throttle, only when you push forward on the trigger? That is a radio/ESC problem, not a motor problem. What transmitter do you have? What ESC? You may have to re-bind/program the ESC and the transmitter together again.
        • jacobo.jajati
          • 22
          I FOUND IT
          i had another exact remote changed the crystal and we are off to the races, perfect running boat
          i will be popping open the remote tomorrow,
          i bet the TRIGGER is not in the correct position in the remote.
          for now fixed thanks for the quick reply
          stay tuned becouse in a few minut here come another interesting one.
